[solved] (Dangerous) behavior from the sketcher
Re: Dangerous behavior from the sketcher
If you alway make your sketches fully constrained, there is nothing dangerous. If you don't, there is always some increased potential for dangerous things.
I don't know what's the context of your business and who are your customers, but feeding them with development version is IMO a harmful choice.thomas-neemann wrote: ↑Tue Jul 27, 2021 1:21 pm That's right, but I felt like I was far out of the window and told my customers that it was reliable. it is enough for me to switch off the circle with e points. i change the title
- thomas-neemann
my customers have version 0.19 stable, but that is not yet "1.0"openBrain wrote: ↑Tue Jul 27, 2021 1:24 pmI don't know what's the context of your business and who are your customers, but feeding them with development version is IMO a harmful choice.thomas-neemann wrote: ↑Tue Jul 27, 2021 1:21 pm That's right, but I felt like I was far out of the window and told my customers that it was reliable. it is enough for me to switch off the circle with e points. i change the title
at 0.19 there is the same problem
Re: (Dangerous) behavior from the sketcher
OK I looked at the video (several times) and now I think I understand. Probably there was some wrong terms used in the OP.
Actually the problem is : "3-point circle geometry does not correctly handle automatic constraining at creation time".
In the video, no automatic constraint is proposed with axis (while they are highlighted) - should be point-on-line -, and point-on-line is proposed with root point - should be coincident -.
Did I get it right?
Did I get it right?
- thomas-neemann
I did that afterwards, but that didn't remove the error. you don't even notice it because you don't know the size of the step reference.
- thomas-neemann
openBrain wrote: ↑Tue Jul 27, 2021 1:31 pm OK I looked at the video (several times) and now I think I understand. Probably there was some wrong terms used in the OP.
Did I get it right?
i work with a translator. I guess we don't have any more misunderstandings now.
Ok. IMO it's always good to add a notice on bottom of a post that is automatically translated.thomas-neemann wrote: ↑Tue Jul 27, 2021 1:35 pm i work with a translator. I guess we don't have any more misunderstandings now.
Now we are clear, there is indeed a bug (at least on your video, didn't try to reproduce yet).
On the technical side, this is just an inconvenience. But on the user side this is really a significant malfunction as one would probably not pay attention to that and then get weird results.
As soon as one will confirm, please somebody create a ticket.
I had it already mentioned in the German forum: It works on macOS correctly.
OS: macOS 10.16
Version: 0.20.25311 (Git)
Hash: c5524bb58a7126fa2242d6137eb82ee9d54e82d4
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.2
- thomas-neemann
do you (or someone else) know whether freecad works under mac os in the virtualbox
I'm really struggling to see how the auto constraints can work in one OS and not in the other two, I've found one set of inconsistent coding between the 3 point arc and 3 point circle and my Linux compiled build now allows coincident constraints to be picked from vertices as expected in the 3 point circle but more burrowing is required to fix everything.
