[solved] (Dangerous) behavior from the sketcher
- thomas-neemann
Re: (Dangerous) behavior from the sketcher
so that no damage occurs, I have removed the circle function from three points until the repair from the menu bar.
FreeCAD runs on macOS in a Parallels/Ubuntu install.thomas-neemann wrote: ↑Tue Jul 27, 2021 3:21 pm do you (or someone else) know whether freecad works under mac os in the virtualbox
Re: [workaround] (Dangerous) behavior from the sketcher
I have tried on the mac in the virtual Ubuntu machine and can confirm the incorrect behaviour compared to the native macOS version.
OS: Ubuntu 16.04.7 LTS (Unity/ubuntu)
Version: 0.20.25288 (Git) AppImage
Hash: bbb557aab6129efd9486d6df19f06c2976fdb7e5
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Qt version: 5.12.9
OCC version: 7.5.2
I can confirm with 0.19.2 and below version on Kubuntu 21.04.
It's even stranger as 3rd point on an axis leads to a tangent constraint. ---
OS: Ubuntu 21.04 (KDE/plasma)
Version: 0.20.25180
Hash: d3800cc36b5271e59977b4a608cdc6ae6fa1cf65
Python version: 3.9.5
Qt version: 5.15.2
OCC version: 7.5.2
Locale: French/France (fr_FR)
Version: 0.20.25180
Qt version: 5.15.2
OCC version: 7.5.2
on macOS it proposes the tangent as well, while over one of the axes at an arbitrary point. The autoconstraint changes correctly to point-on-line when over the origin.
I read on the thread you said "it runs fine on MacOS". I'm interested in having some details about what exactly is behaving differently as it happens that what we see on Ubuntu is precisely what is coded.
And it brings another question to the community : what we would like to happen ?
Please be precise on what constraint should be applied for :
* 1st click on a point ; on a curve (curve is line/arc/circle/... all together)
* 2nd click on a point ; on a curve
* 3rd click on a point ; on a curve
EDIT : I mistook in previous post. I think it's obvious that for points it should always propose point-on-line...
I am heavily surprised: Today I wanted to check the behaviour on a geometric line element, and there autoconstraints worked correctly. After that they worked on the axes too.
And here comes the real surprise: it works always now; even after restarting with a plain vanilla config file
Can anyone confirm?
Can anyone confirm?
This is how it works on macOS and (currently, see above) on Ubuntu. I would prefer a point-on-object constraint for the third point as well, but tangent is ok too.
- threePtArc.webm
- (499.82 KiB) Downloaded 28 times
I think there is some misundertanding. (If I'm correct) OP is specifically talking about behavior of 3-pt circle, not 3-pt arc.
To me 3pt-arc is pretty correct, but 3-pt circle is indeed pretty weird.
Could you have a check on 3-pt circle too ?
I mixed things up: 3-point-circle acts as shown in your screen cast on macOS too. I don't think it's really weird. The only thing missing is a proposal for a tangent constraint for the first point.
