Hello every body,
I am trying to make a cut of a body with a compound of a cylinder and a cube. but I got a bud result.
The shap became black. If I change the position of the cylinder or the cube (z< or> 0) the colour is a gain grey (default colour). but the intersection of the cube and cylinder, together, with the body remains in place. there is no cutting !
19.2
OS: KDE Flatpak runtime (X-Cinnamon/cinnamon)
Version: 0.19.14555 (Git shallow)
Python version: 3.8.8
Qt version: 5.15.3
and in freecad 0.20
with freecad 0.OS: Linux Mint 20.1 (X-Cinnamon/cinnamon)
Version: 0.20.25220 (Git) AppImage
Hash: 46282db7c8c65d1205a4cd03499d4beadb1573c6
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Is it possible to make a cut of a body with a compound
- mwlandolsi
Re: Is it possible to make a cut of a body with a compound
You might need to make a union of the compound if the objects within the compound intersect one another because self-intersections will usually cause subsequent boolean operations to fail. Alternatively, make a union instead of a compound in the first place.
- mwlandolsi
Thanks for your support. I did not Know that creating a compound is not for intersection shapes.
Ok
but I did not find this in Preferences
Ok
Try 'RunBopCheck'.......
Actually the wiki is a little out of date here since 'RunBopCheck' can be enabled from the Part checkgeometry menu item, it's a check box in the dialogue.
Where did you find this in the wiki? The documentation of Check geometry is correct.
