PartDesign Gui (Editing Revolve and Helix selection logic)
Re: PartDesign Gui (Editing Revolve and Helix selection logic)
With the primitives I have the feeling it is quite natural to realign them, at least that's what I often want if I double click on them.
After more testing it appears (at least on my Win10 system) the Revolve "Update view" works differently than the Helix Update view.
If I uncheck the "Update view" on a Helix edit, and then select an Origin Axis in the 3D I see an update in the task panel Axis field. Can someone verify this, it looks like TheMarkster has different results.
That looks right on target, Thanks TheMarksterTheMarkster » wrote
I couldn't reproduce the issue with the additive helix
and
Edit: https://github.com/FreeCAD/FreeCAD/pull/4944
I cannot confirm. Nothing is updated here if the "Update view" box is unchecked.
Thanks chrisb.
Since I see this issue differently on my system I will make a general statement:
The "Update view" is common to Revolve, Helix, both Additive and Subtractive functions, whatever code is used to fix the Revolve should probably be inserted in the others.
I also see some issues with selection being automatically enabled with Datum selection but I'm not sure how these should work.
Thanks
Thanks
The selection mechanism via click into 3D view should be enabled if and only if "Select reference ..." is chosen. This is never the case on entering the panel.
