When is a solid not a solid?
I have modeled a (roughly) triangular solid
SNAFU! My Bad! What have I done wrong?
and I wish to Sweep a Web around it.
When I do so It is not a solid! SNAFU! My Bad! What have I done wrong?
- 210730 AP-00-000.FCStd
- (45.83 KiB) Downloaded 30 times
"It is much harder to simplify than to complicate."
Joseph Kimble
Joseph Kimble
Re: When is a solid not a solid?
Break the path sketch into two pieces and you can complete the sweep.
You will need to copy the sketch, since splitting the existing sketch will break the idler arm pad.
Loops should be allowed as the sweep path, but it did not seem to work in this case.
Gene
Gene
I am afraid I don't know what you are talking about GeneFC.
I Googled freecad copy sketch and got
1. Select sketcher element for copy operation.
2. Click on the Sketcher Copy button in the toolbar or choose Sketch → Sketcher tools → Copy from the Sketch menu.
3. Place copy in the 3D view.
Then I tried to select the path and found that the lines that make up the path are individual. That means the path is already broken into six pieces.
I'm all confused.
Incidentally, I have done this web trick umpteen times before and never had this problem.
Joseph Kimble
Joseph Kimble
Got there! I selected the Idler Arm Web Sketch and clicked Sweep then added the edges in the Idler Arm Sketch one at a time.
Thanks
Joseph Kimble
Joseph Kimble
- Shalmeneser
It works, but in my tentative, the pad disappears.
I've redone the AdditivePipe in a new files and it should always work.
I don't understand the problem with your file.
- Perthfectible.FCStd
- (37.05 KiB) Downloaded 17 times
- 210730 AP-00-000 BUG.FCStd
- (80.53 KiB) Downloaded 15 times
- papyblaise
I did a lot of retouching, I ended up finding extra points in the 2 sketches, but I looked so hard that I no longer know where
- 210730.FCStd
- (47.65 KiB) Downloaded 16 times
- 210730.PNG (19.85 KiB) Viewed 819 times
- Shalmeneser
You can Pad but not Pipe after.
You can Pipe but not Pad after.
So where is the problem ?
- Shalmeneser
I've modified the big round's Idler Arm Web Sketch.
- 210730 AP-00-000 OK.FCStd
- (51.41 KiB) Downloaded 16 times
This was what I had and this is what you have All I can see is the two equality constraints where you specified the 16mm curve diameter to be equal to the construction line curve diameter.
Is that all you did?
Then the Pipe worked okay?
Joseph Kimble
Joseph Kimble
Greetings to the Community!
My general rule for creating sketches:
- reduce the constraints as much as possible;
- prefer geometric constraints to dimensional ones.
Good weekend
Good weekend
- 1.png (215.04 KiB) Viewed 724 times
- 2.png (243.3 KiB) Viewed 724 times
- (50.38 KiB) Downloaded 25 times
