Newbie alert: Only able to keep one feature of a body active at one time
jttrey3
Post by jttrey3 »
I have been watching many videos and following along to learn the product, and I am loving it. I am trying to model a battery. It is a rectangle which I padded, then colored specific faces. I then added two pockets, and colored the face of each (red and black). I then added a chamfer around the top edge. However, If the chamfer is active, then the pad and the two pockets become inactive. If I activate any other feature (I hope this is the correct term), only that feature stays active. While this seems like expected behavior, the color changes I make to faces only appear when that feature is active.
See attached screehshots and file.
I am sure I have probably done something foolish, but I cannot determine what, nor has my googling hound any answers.
I am using the .19 Appimage for Linux, with no additions or modifications.
OS: Ubuntu 20.04.2 LTS (ubuntu:GNOME/ubuntu)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Sadly, I am not even sure I have learned enough to ask the right questions. Any assistance would be appreciated.
Thank you
John
20210730-Battery1.4.FCStd
(34.44 KiB) Downloaded 13 times
Re: Newbie alert: Only able to keep one feature of a body active at one time
Hi and welcome to the forum!
Colors are indeed a per feature property, so it is best to leave coloring until the very end of the modeling.
Besides, your wording is misleading - or show that you are mislead: You don't activate features, you make them visible. They are not standalone objects, they describe subsequent steps in the modeling process.
We use the word activate for bodies, which switches a body into a state where the next feature goes into.
jttrey3
Post by jttrey3 »
Thank you Chrisb.
I appreciate the information and context. I will skip colors until the end and adjust my terminology accordingly.
Cekuhnen
Post by Cekuhnen »
Also names can be tricky
You cannot have the same name twice
Often I don’t name features and only the body.
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
Cekuhnen wrote: Sat Jul 31, 2021 3:49 pm Also names can be tricky
First: you have to distinguish between the name and the label of an object. You cannot change the names at all, they are always unique. You can change the labels and they even can be identical, although I don't recommend that at all. I don't know what happens if you have identical labels and use these in an expression.
Second: the names of the objects are completely independent from the coloring discussed here. You may have heard of the topological naming problem, which talks of "names" as well, but these are the internally used identifiers for the faces, edges, vertices, which are always numbers.
