Sketch on body face flipping problem
Cekuhnen
Re: Sketch on body face flipping problem
Post by Cekuhnen »
sure here:
The arc flip is interesting:
https://drive.google.com/file/d/1DPqytQ ... d_HEA/view
Screen Shot 2021-07-31 at 3.26.52 PM.png (50.56 KiB) Viewed 726 times
Screen Shot 2021-07-31 at 3.26.41 PM.png (41.09 KiB) Viewed 726 times
Trim Surfaces Raw.FCStd
(10.82 KiB) Downloaded 20 times
MacOS Big Sur / Win 10
Designer | Faculty
Wayne State University
Interior - Industrial Design
GeneFC
Post by GeneFC »
Cekuhnen wrote: Sat Jul 31, 2021 7:28 pmsure here:
I tried multiple ways to duplicate the so-called flip, following your video, and I could not. I am using a very recent version of FC, 20.25306.
Then I realized you were using version 0.19. When I tried that version I was able to make the *sweep* flip.
Neither sketch actually flipped in any case, including the release version 0.19. The sweep flipped, but that is an entirely different problem.
When a sketch flips it will be completely obvious while one is still working in the sketcher. I can make it happen at will if I greatly scale up or down the existing elements in a sketch. I try not to do that. :o
Gene
Cekuhnen
Post by Cekuhnen »
GeneFC wrote: Sat Jul 31, 2021 9:57 pm Neither sketch actually flipped in any case, including the release version 0.19. The sweep flipped, but that is an entirely different problem.
Very interesting - could you elaborate?
I should have stated that I was using 0.19.
But I have this with 0.2 too and also RealThunder
See here:
https://drive.google.com/file/d/1ExDsVV ... 1M7Lt/view
It seems the moment the sweep path top point when switching from going to the right side going to the left side is the moment
the second sketch flips
Designer | Faculty
Cekuhnen
Post by Cekuhnen »
Here I remember a similar issue with sketch elements flipping on its own - but I do use projection of faces
https://forum.freecadweb.org/viewtopic. ... 57#p520257
When I have a moment I will do the screen cast
Have the baby on my arm now
Designer | Faculty
Flipping sketches are well known and discussed in the forum every now and then. They can occur when a solution for solving the constraints is not unique. It is a solver issue, which is ok, though unexpected.
What you describe in the OP is something different where the attachment mechanism is involved. Again it is ok, because all required conditions for the attachment are fufilled.
GeneFC
Post by GeneFC »
Cekuhnen wrote: Sat Jul 31, 2021 11:20 pm Very interesting - could you elaborate?
The distinction might be fleeting, but there is a major difference between the classic "sketch flipping" and what you are seeing. Sketch flipping is an old problem, and it has been quite actively addressed and mostly controlled.
Here is a set of before and after screen shots to show what I am saying.
All of this is in version 0.19.
Before (as loaded)
Main Window Before.png (19.39 KiB) Viewed 636 times
Sketch003 Before.png (5.46 KiB) Viewed 636 times
Sketch004 Before.png (1.56 KiB) Viewed 636 times
After moving Sketch003 a bit
Main Window After.png (23.25 KiB) Viewed 636 times
Sketch003 After.png (4.65 KiB) Viewed 636 times
Sketch004 After.png (1.55 KiB) Viewed 636 times
As can be seen, Sketch004 did not change from a frown to a smile. It looks unchanged. However, the *attachment* of Sketch004 to Sketch003 as part of the Sweep operation did indeed "flip".
I am in no way arguing this is good, but it is a different problem than sketch flipping. As I noted above, the attachment problem appears to be fixed in version 0.20.
For this test:
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24267 (Git)
Hash: b2ca86d8d72b636011a73394bf9bcdedb3b109b7
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Gene
Cekuhnen
Post by Cekuhnen »
Got it - thank you for the explanation and pointers.
Here is a recording of the chaos I can see inside my parametric side stand.
NOTE: I apply a little the workflow I am simply used to, work with professionally, and teach - with Fusion360
and I was curious to see how this could be applied to FC and RealThunders build.
https://drive.google.com/file/d/1tI_6VO ... hsyij/view
Side Table2.FCStd
(309.58 KiB) Downloaded 15 times
Designer | Faculty
GeneFC wrote: Sun Aug 01, 2021 12:52 am As I noted above, the attachment problem appears to be fixed in version 0.20.
I can reproduce the flipping attachment in 0.20.
OS: macOS 10.16
Version: 0.20.25311 (Git)
Hash: c5524bb58a7126fa2242d6137eb82ee9d54e82d4
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
GeneFC
Post by GeneFC »
Here is a very simple-minded exhibit of what is commonly called sketch flipping.
Incomplete shape:
Select lower right open ends and use coincident constraint. What was wanted:
What actually happened:
The upper right line segment has "flipped".
Some cases are more complex or subtle, of course, but this is the general concept of sketch flipping.
Gene
GeneFC
Post by GeneFC »
I played with this example a bit more and came up with an even more curious observation.
The attachment details and model shape seem to depend on the orientation of the end of the line in Sketch003. When the end of Sketch003 is exactly vertical there is a different result from what was shown previously.
Vertical end.PNG (5.23 KiB) Viewed 527 times
Intermediate case.PNG (21.68 KiB) Viewed 527 times
The attachment goes through some sort of transition state.
Gene
