That's how I had started yesterday too - and failed. Please add the Multipattern and check if it still works.papyblaise wrote: ↑Mon Aug 02, 2021 9:44 am green : mine , white : yours , you can see it's same result
Freecad Idomatic Method for Radial Cylindrical Cutouts
Re: Freecad Idomatic Method for Radial Cylindrical Cutouts
- papyblaise
I think I understand your question, if I do the boolean add-on of Body + Body (the clone returns) it doesn't work either, so I did it in PartWb
- Shalmeneser
Z-axis for the general reference = Y-axis for the local reference of the Datum plane.Shalmeneser wrote: ↑Mon Aug 02, 2021 9:23 am I need to rotate around the Z-axis by 45° (so Datum plane), ...
I was seeing your file but not looking at enough : Symmetric.1mm above XY to have enough material to make an R = 5
Greetings to the Community!
.... another example of workflow to obtain the flange, attached the file containing the technical drawing obtained with TechDraw.
- Flange.FCStd
- (253.57 KiB) Downloaded 35 times
- Flange.png (301.61 KiB) Viewed 882 times
- TechDraw_Flange.png (67.35 KiB) Viewed 882 times
Version 2, incorporating GeneFC's idea.
Note the volume as shown in check geometry shape content for comparison to other models: 16487.724257.
I was curious about something, so I added another object, an array of 3 cylinders, then placed them to see if the sides of the cylinders would align with the sides of the holes in the part. They don't, but I'm not really sure how this part is supposed to mate up with other parts.
- flange_markster_v2.FCStd
- (196.41 KiB) Downloaded 37 times
- Shalmeneser
Using ideas from other : Pad + Substractive Pipe
But the Pipe smokes and doesn't want to work.
- LordOfTheRingBell.PNG (100.37 KiB) Viewed 812 times
- LordOfTheRingBell2.PNG (35.09 KiB) Viewed 812 times
- LordOfTheRingBell.FCStd
- (30.42 KiB) Downloaded 30 times
- papyblaise
it's not easy to innovate
- flange4.PNG (17.36 KiB) Viewed 803 times
- (271.51 KiB) Downloaded 30 times
Definitely not the least tedious way to solve the issue...
But, to add to the possibilities:
- Flange-mac.FCStd
- (621.19 KiB) Downloaded 36 times
