Freecad Idomatic Method for Radial Cylindrical Cutouts
- Shalmeneser
Re: Freecad Idomatic Method for Radial Cylindrical Cutouts
Do not look at Placement, but Attachment.
It is not the same, Chris.
And I am afraid that Willem's solution is incorrect. See my remark somewhere lower in this thread as a response to Willem.
Greetz
Roland
Well, that Attachment is wrong as it intersects with the origin! So, I agree with you: we need a datumplane. At least one.
And if you want to use the Groove feature, you need also to find the axis around which to sweep the sketch, and that axis is NOT the Z axis of this model.
Perhaps this illustration helps to better grasp the matter: See also the comment by Papyblaise.
I am trying some more potential solutions inside Part Design. So far I could only manage with a combination of Part Design ad Part.
Happy modelling!
Roland
- Shalmeneser
Sketch002 : Support : DatumPlane(000)
DatumPlane(000) :
* Support : YZ_Plane
* Attachment : Y angle = 45°
DatumPlane(000) :
I see what you mean. Yes, it is not a circle.Roland wrote: ↑Sun Aug 01, 2021 9:34 pmMarkster, I think that your solution is wrong because what should have been a circular cylindrical surface is actually an elliptical cyclinder. This is because you sweep a circle along an angled direction.TheMarkster wrote: ↑Sun Aug 01, 2021 9:22 pm Could be there are better or more efficient ways to do it.
Best regards,
Roland
Edit: but looking at the original picture it appears it could be elliptical. It is hard to say from the image.
Seems like that is very easy to remedy. Just make two profile sketches at the correct angles instead of trying to make do with one in the middle.
Gene
Yes, that would be the way to do it, assuming you want circles for those faces. I'm not yet convinced that is what the original is depicting.
Hi
Do you think I got it?
hpb
OS: Windows 10 (10.0)
Version: 0.20.25334 (Git)
Hash: 433c52c290681992346b6cda6482bf6a73d74e25
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Locale: German/Switzerland (de_CH)
hpb
Qt version: 5.12.9
OCC version: 7.5.2
- Flange_hpb.FCStd
- (219.91 KiB) Downloaded 39 times
- papyblaise
See the solution of hpbmoIf someone can do without the Datum plane ...
I was going to offer you another one, but it's useless, it's up to you to invent one
- flange2.FCStd
- (355.51 KiB) Downloaded 33 times
Almost. Fillets which consume the whole adjacent face and touch the thext edge frequently fail. So I'm afraid this solution works just here.
