Freecad Idomatic Method for Radial Cylindrical Cutouts
Re: Freecad Idomatic Method for Radial Cylindrical Cutouts
I know, that fillets are sensitve. So I set the fillet radius to 4.999 mm. And if I use an expression, should it work with different dimensions
- papyblaise
the radius will be limited to 4.9999mm if the precision is not enough (for the perfectionistics ), you do as in my last post:
a half horizontal piece which is higher than the XY plane, you make the radius of 5mm and a miror, the radius of 5 will be perfect
Hi Papyblaise,papyblaise wrote: ↑Mon Aug 02, 2021 6:31 amSee the solution of hpbmoIf someone can do without the Datum plane ...
I was going to offer you another one, but it's useless, it's up to you to invent one
Maybe useless, but this seems to me a very challenging modelling problem from which we can learn a lot in using Part Design WB and Part WB.
Your solution does indeed reproduce the original paper drawing. However, if I analyse your model I find a circular reference in the boolean operation that FC apparently cannot resolve:
I wonder how you were able to create it at all!
To avoid the circular loop, I propose to make a clone of the body before the boolean, turn the clone along x by 180 degrees, and fuse the two bodies. Like so: Best regards,
Roland, on
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
- Shalmeneser
I was asking if someone could, inside MY file, do without the Datum plane.
I need to rotate around the Z-axis by 45° (so Datum plane), then move front (enough) (so Sketch Attachment). Is it possible to do everything in the sketch Attachment ?
- papyblaise
I don't know, it worked perfectly without a magic wand, so I couldn't answer
- Shalmeneser
Your first pad is "2 lengths : 10 & 1" ???
OS: Windows 10 (10.0)
Version: 0.20.25311 (Git)
Hash: c5524bb58a7126fa2242d6137eb82ee9d54e82d4
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Locale: French/France (fr_FR)
Sorry, I had set my precision to 2 decimals and didn't see the two lines. I was already slighty delighted, that OCC had improved the fillets.
It is indeed interesting and I still don't fully understand why the PartDesign Pattern needs the sketch to have an offset. Even manual setting of the Overlap property didn't help.
- papyblaise
as I said, to be 1mm above XY to have enough material to make an R = 5Your first pad is "2 lengths : 10 & 1" ???
he ben alors you don't how do that ...I need to rotate around the Z-axis by 45° (so Datum plane)
you who give the impression of taking everyone back to do better
you just have to draw it on the XZ plane and turn it on its Z by 45 °
you just have to know that its Z is the Y of the general reference
each time you change the local plane, the Z of the sketch is perpendicular to the screen, which is not the same as in the general
it is thus in all the CAD that I know (tous les CAD le sont french jok)
green : mine , white : yours , you can see it's same result
- flange3.PNG (29.48 KiB) Viewed 1078 times
Sort of:Shalmeneser wrote: ↑Mon Aug 02, 2021 9:23 amIs it possible to do everything in the sketch Attachment ?
- Attach the sketch with Mode FrenetTB to the 60° arc of Sketch
- To get 45° of these 60° we use the MapPath parameter with the factor 45/60 = 3/4
- Add an offset to z direction of 10mm
- Reverse the pocket
- LordOfTheCB.FCStd
- (150.02 KiB) Downloaded 37 times
