B-spline_xyz? for surfacedesign
Hello together,
our implant was designed using Siemens NX, now we have to use FreeCad for another version of plate. the idea is to create the solid using surface WB
First step: creating an outline of the part using a B-spline in xy
Next step: add the correct z-value to the B-spline points to follow the top-surface. -> B-spline ->data -> points OK and then click gorden-profile
now you see the actuall line.
It works, slow, but it works and, I am sure, the gorden line button is not correct for this work, but I have no idea what to do to increase.
Any ideas are wellcome
thanks
norus
OS: Windows 10 (10.0)
Version: 0.19.23074 (Git)
Hash: 74b866ed3022fd1452c534dae31a721bcc668f2f
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
thanks
norus
Qt version: 5.12.5
OCC version: 7.4.0
- B-spline_xyz for surface.PNG (371.17 KiB) Viewed 1560 times
Re: B-spline_xyz? for surfacedesign
Should I merge this with the Curves workbench topic? If not, then you should make clear that it is about this addon workbench by using an appropriate title for the topic.
I understand that it is part of B-spline, how to get a third parameter for the coordinates.
But I am not familiar with the structure of Freecad, only pragmatic user.
- thomas-neemann
hello norus
is a 3d bspline helpful? example in the video:
https://www.youtube.com/watch?v=xwn3eMvsvBY
Greetings Thomas
edit
ergänzung
https://www.youtube.com/watch?v=aseHIOLt4YA
edit 2
2. ergänzung
https://www.youtube.com/watch?v=nv43Z0d9Jwo
thats what I am looking for.
a mechanical engineer finds the solution using Arch, excellent !!!!!!
Have a great time, stay save.
Thanks a lot.
norus
Thanks a lot.
norus
- thomas-neemann
arch contains draft and draft is a real 3d tool, it is often wrongly described as a 2d tool.
Greetings Thomas
My problem is to activate the third coordinate-value, there is always the result in xy or yz....
There is a hidden button to get your results.
- thomas-neemann
this snap option is important
There is a problem, but where?
In Combo I see line not bspline, the button ist activated
- B-spline-Linie.PNG (25.71 KiB) Viewed 1400 times
- B-spline-bspline.PNG (139.02 KiB) Viewed 1400 times
- Bspline_geht_nicht.PNG (179.89 KiB) Viewed 1400 times
It works, FreeCad reinstalled.
But in Combo-view I see line not Bspline.
Thank you Thomas, its a big help.
