for me it is the case when the spline has no curvature. then there is also line in the combo view.
B-spline_xyz? for surfacedesign
- thomas-neemann
Re: B-spline_xyz? for surfacedesign
... you can also do a lot with PartWB, Sketcher and Boolean_Common e.g.
There would be more insight for help, if you give us an understandable picture.
- Plate.FCStd
- FC.18.4
- (439.46 KiB) Downloaded 26 times
Thanks a lot,
bspline from arch is a very important function using curves and surface WB. Especially if you have to digitize 3D-parts like implants or bones.
Just now I am very happy with this solution and when finished I will show here.
Thanks again
Thanks again
Thank you hammax,
thats perfect for our new parts.
... the plate more "irregular" with placement operations.
- Plate_2.FCStd
- FC.18.4
- (789.57 KiB) Downloaded 25 times
.....amazing,
I give it a try.
I give it a try.
- Shalmeneser
with PartDesign wb. (Fillets are too heavy for the forum)
- NimporteQuoi.FCStd
- (887.29 KiB) Downloaded 24 times
- Capture.PNG (181.57 KiB) Viewed 1231 times
I learn a lot, thats what I am looking for a long time.
thank you
norus
thank you
norus
here a example I am breaking my fingers and some synapses.
https://www.dropbox.com/s/71qsh6zie4y9o ... .step?dl=0
the question is how to design it from zero.
greetings
norus
greetings
norus
- spitze_2.PNG (44.28 KiB) Viewed 1169 times
- spitze_1.PNG (46.03 KiB) Viewed 1169 times
... the step.file is rather big for linking, but imported to FC it fits into the data limit.
To reduce the solid to a more simple design the radii must be removed, for getting bottom and top shape.
Designing cross sections you are able to use sketches on those sections and build shapes.
Something like Spitze_3 => quick and dirty!
If the file name "Spitze" implies a German source, please go to this subforum.
- Spitze_3.FCStd
- FC.18.4
- (896.32 KiB) Downloaded 18 times
- Spitze_2.FCStd
- FC.18.4
- (639.77 KiB) Downloaded 22 times
