spout for a cup - loft? help!
Hi Guys,
ok so maybe this is not a simple thing, I need to do a loft from a curved surface to a curved surface i think...
I'm trying to create a "simple" spout from a cup, but I've searched everywhere online and I can't find any pictures/tutorial or anything that
shows this is even possible in FreeCAD...
I've attached a cylinder with two surfaces to loft between... anyone know if this is possible?
Alternatively, anyone know how to make a simple curved spout?
Perhaps a top and bottom sweep profile alone 2 rails using the Curves addon workbench?
- loft.FCStd
- (61.8 KiB) Downloaded 20 times
Re: spout for a cup - loft? help!
Hi and welcome to the forum!
Normally you would create a Draft->FaceBinder and then add a Part->Loft. However, this crashes FreeCAD here, in master as well as in realthunder's branch.
OS: macOS 10.16
Version: 0.20.25311 (Git)
Hash: c5524bb58a7126fa2242d6137eb82ee9d54e82d4
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.2
- thomas-neemann
if that is a solution for you, i can make a video about it.
- papyblaise
we saw him no later than 1 to 2 weeks
- cup of milk.FCStd
- (273.53 KiB) Downloaded 26 times
- cup of milk.PNG (21.97 KiB) Viewed 1000 times
hmmm yeap, thanks guys, all solutions i guess, but not quite what I wanted, because lets say the material is 1mm thin, like a stainless jug, it would be difficult to create a flowing/bent connection of the spout to the metal, it's be a shape angle connection, you'd then need to chamfer the sharp edge on the inside, but how do you do an add material chamfer on the outside (i.e. a weld) ... you really want a loft that can go from a curved surface to a curved surface along a path...
scratch that, I think the above ideas might work, you put in a larger chamfer on the outside of the spout/cup connection like this...
https://www.youtube.com/watch?v=oWTizlRcDnk
and then I'm guessing one on the inside... that might work, I'll try it tomorrow.
- papyblaise
voilà , you can miss-miss the cat
- cup of milk2.PNG (11.37 KiB) Viewed 944 times
Ah yes ok that works, hugely laborious haha, but smooth curved surfaces, still ugly as all hell... but I'll post it up here for reference... lots of errors during production where it won't allow you to do lofts and cuts if it results in two solids... but works!
- cup spout.FCStd
- (491.65 KiB) Downloaded 22 times
But this specified behavior.Greg_melbourne wrote: ↑Tue Aug 03, 2021 12:19 am ... you to do lofts and cuts if it results in two solids...
A Part Design workbench Body can only contain a single contiguous solid. All feature operations must result in a single solid. The Body is the cumulative result of all features under the body.
- papyblaise
Miaou yes and I'm waiting for my milk miaou
in general, in bars, they are conical
and I do it without DatumPlan, and using the Pad face for the AddPipe
I gave it a profile a little less "eagle's beak"
Miaou
Miaou
- cup of milk spout.FCStd
- (505.7 KiB) Downloaded 13 times
- cup of milk spout.PNG (26.82 KiB) Viewed 858 times
drmacro, yes but for a beginner it's not clear why things are failing, and you're left scratching your head... just wish there was more descriptive error messages... but totally usable CAD software, I love it.
