OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Hello
I am not sure if this is a bug or I'm not doing something correctly. When I try to export Wires from an Assembly 4 model, the wires lose their 3D coordinate reference. All wires export with an origin on 0,0,0 which is not the case. From what I can see it looks like it doesn't transfer the position of the Model to the sub-elements.
So when I import the DXF into my next software the lines are in the incorrect position.
Has anyone else this problem or some guidance on how to fix?
Thanks.
Problem exporting to DXF from Assembly 4 Wires
Re: Problem exporting to DXF from Assembly 4 Wires
A little more context. Each Assembly model has been duplicated from a "template" In this case the Assembly Model named "leaf_template"
So for example "leaf_001" is a duplicate of "leaf_template". I then translated and rotated "leaf_001". I did a quick test exporting multiple Wires. And it appears that they are being exported all in the XYZ position and rotation of the original geometry they were duplicated from.
