empty navigator cube
Mikele
Post by Mikele »
Hello guys,
I´m a new user.
Version 1.8, Win7 64bit, (I should probably install 1.9?)
My navigation cube is empty. There only is a white square.
What to do?
Thanks and best regards -
Michael
Re: empty navigator cube
Post by Kunda1 »
First update to 0.19.2 and report back
And if it doesn't work in 0.19, you should try the latest 0.20.
Mikele
Post by Mikele »
0.19.2 does not run at all. error ...
0.18.4 stills runs like before.
Mikele wrote: Tue Aug 03, 2021 2:09 pm 0.19.2 does not run at all. error ...
You can try to reset the configuration with the button in the preferences. Another possibility is to delete your config files or to move them in case you want to restore them.
Beyond that, nothing will be done with 0.18 from the developers side. For 0.19 you may check the Known OS specific issues. From your very sparse message it is hard to help.
Post by Kunda1 »
@Mikele help us help you. To piggyback on chrisb's message, please be a lot more elaborate. The more you are the easier it is for us to help you.
onekk
Post by onekk »
Mikele wrote: Tue Aug 03, 2021 9:50 am Hello guys,
I´m a new user.
What to do?
Michael
See this:
https://forum.freecadweb.org/viewtopic.php?f=3&t=2264
And post the complete FreeCAD version copied usign this method:
https://forum.freecadweb.org/viewtopic. ... 10#p423310
Regards
Carlo D.
- Various other stuffs.
Mikele
Post by Mikele »
sorry for not following the rules and recommendations.
Found e.g. this:
*Windows display driver
There are issues with Radeon graphic cards. If your objects show transparency where they should not, it may be caused by the Radeon driver.
Workaround: Rollback to an earlier driver graphic card driver version.*
Hm, my graphic card is an old Radeon HD 5450.
My system:
OS: Windows 7
Version: 0.18.4 (GitTag)
Branch: releases/FreeCAD-0-18
Python version: 3.6.6
Qt version: 5.6.2
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
TheMarkster
Post by TheMarkster »
I have the radeon hd 4550. I had this issue with some of the 0.18 versions, but 0.19 and afterwards all worked fine. I think it had to do with the version of Qt used in 0.18, or perhaps it was coin version. The 0.18 version made with python2 worked fine also.
Mikele
Post by Mikele »
... after deleting the certain files 0.19 is running now. No software crash. :)
Still no navigator cube, only white square.
I forgot to mention that the different object views did not work immediately or that I had to click outside the screen first. Now this works too!
Do you really need the cube?
I am a 1/2 DAU in computers but imho my graphics card is overwhelmed?
Could deinstalling Version 0.18 help too?
* There are issues with Radeon graphic cards. If your objects show transparency where they should not, it may be caused by the Radeon driver.
I'm really scared that something happens that I can't get back on if I change the driver version of the graphics card.
