Sheet Metal Workbench
Re: Sheet Metal Workbench
My apologies, how do I get help here? My problem is trivial but at this point without a manual, documentation or reference I cannot go further. Please let me know hw I can improve my questions. Thanks you all!
The 'Skecth on face' stay grey on my system as well.
In [Part Design] I select the face and then select 'Create Sketch'. If you open the [Tasks] tab of the combo View it will show 'Face Tools'
Adie
Adie
Marvelous , thank you, Adie! It worked!!!!
The Sheetmetal Workbench is still a bit rough around the edges. (I came from Solidworks and Fusion)
One of the biggest tips, Save at regular intervals EITH NEW FILE NAME and test if you can flatten after each complex new feature.
MAHE SURE NO FLANGE EDGES TOUCH or you will get the dreaded 'Can not Flaten - Try other face' message.
The attached Bashplate was probably designed 10 times before I got it all done.
Also remember the Flat part and sketch is 'detaced' from the model. Any change is local to them only.
It also took me more than 6 tries to get the DXF to import in Sheetcam. All sorts of buggy lined during Flattening.
Look at the little section of the Flat part and the Skecth during editing.
Adie
Adie
- Flat part.JPG (20.23 KiB) Viewed 2153 times
- Edit flat sketch.JPG (76.19 KiB) Viewed 2153 times
- B Plate.JPG (108.04 KiB) Viewed 2153 times
pLs check attached file for one of the method can be used for this shape.
- wedge to sheetmetal.FCStd
- (81.35 KiB) Downloaded 52 times
Look at the first part of this vid to create the base object via the DRAFT function.jaisejames wrote: ↑Wed Jun 09, 2021 3:17 ampLs check attached file for one of the method can be used for this shape.
https://www.youtube.com/watch?v=K0hpkR3c9p4
Adie
- papyblaise
rather than cut at an angle, you can cut in the face, and at an angle if you wantLKM_cad a écrit : ↑ven. juin 04, 2021 9:37 pm
Can someone have a look?
- piramidal pipe.FCStd
- (77.42 KiB) Downloaded 56 times
- piramidal pipe.PNG (11.32 KiB) Viewed 2052 times
Is it standard practice to perform bends like this (like an internal piece of an edge):
If yes, what is the general recommended clearance required (shown as the red dimension below):
(I would ask the people who are going cut and bend it, but theres public holidays now in my country).
- papyblaise
well do not disturb people on their vacation , but it is also the time when they can devote themselves to a hobby like freecad
you make the window that you agree to and you play with Gap1, Gap2, Extend 1, Extend2, Reliefd, and Reliefw to get the values you want
in my example, even if Sheetmetal is not blocked in the unfold, the part does not unfold in real life
- pli latéral.PNG (36.18 KiB) Viewed 1819 times
- pli latéral.FCStd
- (15.51 KiB) Downloaded 39 times
Thanks for the reply. In my picture I modelled it in FreeCAD by adding offset1 and offset2, then I extended the edges that got cut away.papyblaise wrote: ↑Tue Jun 15, 2021 2:13 pm well do not disturb people on their vacation , but it is also the time when they can devote themselves to a hobby like freecad
But my question is a bit off topic, cause it more about, is it generally possible for laser cutting/CNC bending fab shops to be able to make this sort of thing, or is it a design I should stay away from?
