Sheet Metal Workbench
FBXL5
Re: Sheet Metal Workbench
Post by FBXL5 »
jaisejames wrote: Mon Sep 27, 2021 9:18 am Below option is to unfold sheet-metal by suppressing forming feature [Hoping/expecting that it will be last feature in tree view. so top naming issue will not be there].
The embossed geometry has sharp edges to the base plate and needs two fillet operations after it in the design tree. These fillets lose their defining edges, when the forming feature is suppressed.
gigax
Post by gigax »
when I try to use the unfold function, I get this error message:
12:10:09 Engineering mode is not enabled.
12:10:09 Running the Python command 'SMUnfold' failed:
File "C:\Users\andre\AppData\Roaming\FreeCAD\Mod\sheetmetal\SheetMetalUnfolder.py", line 3047, in Activated
taskd = SMUnfoldTaskPanel()
File "C:\Users\andre\AppData\Roaming\FreeCAD\Mod\sheetmetal\SheetMetalUnfolder.py", line 2454, in __init__
spreadsheets = findObjectsByTypeRecursive(FreeCAD.ActiveDocument, 'Spreadsheet::Sheet')
File "C:\Users\andre\AppData\Roaming\FreeCAD\Mod\sheetmetal\SheetMetalUnfolder.py", line 2398, in findObjectsByTypeRecursive
for _o in get_linked_objs_recursive([obj]):
File "C:\Users\andre\AppData\Roaming\FreeCAD\Mod\sheetmetal\SheetMetalUnfolder.py", line 2365, in get_linked_objs_recursive
objects += o.Group[Parts_index].Group
'FeaturePython' object has no attribute 'Group'
If I create a new project and I copy/paste the object into it, the unfold function works well.
Any idea about the cause?
Thanks!
gigax wrote: Wed Sep 29, 2021 7:02 am Any idea about the cause?
Upload the file. Is your FreeCAD current?
gigax
Post by gigax »
chrisb wrote: Wed Sep 29, 2021 7:51 am
Yes let me share the model... You can take any of the parts and try to unfold, and the function will not work.
I am not 100% sure, but I think this problem appearead after I used the Fasteners workbench. You can see some screws and nuts under the Group "Viteria".
My FreeCAD is up to date. Here is my system info:
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Italian/Italy (it_IT)
Many thanks for your attention and support!!!
Stand-Concept.FCStd
(454.83 KiB) Downloaded 70 times
-alex-
Post by -alex- »
gigax wrote: Wed Sep 29, 2021 9:40 am
The issue seems related to fasteners'links objects and only this.
While I suppress links objects of fasteners it works to unfold.
If I create a link from any sheetmetal parts it works to unfold as well.
But if I create a link from a fastener object then unfold fails.
It looks like a bug.
realthunder wrote:ping
Hi RT, what's your opinion about that?
Tks for your attention.
Offtopic edit: the "Stand-concept" file fails to recompute during migration in you Linkstage3 branch. Here is the output:
8:40:26  Traceback (most recent call last):
  File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalCmd.py", line 1096, in execute
    mingap = fp.minGap.Value, maxExtendGap = fp.maxExtendDist.Value)
  File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalCmd.py", line 679, in smBend
    mainlist, trimedgelist = getBendetail(selFaceNames, MainObject, bendR, bendA, flipped, offset, gap1, gap2)
  File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalCmd.py", line 352, in getBendetail
    lenEdge, selFace, thk, revAxisV = smEdge(selFaceName, MainObject)
  File "/home/pi/.FreeCAD/Mod/sheetmetal/SheetMetalCmd.py", line 342, in smEdge
    selFace = smFace(selItem, MainObject)
<class 'NameError'>: name 'MainObject' is not defined
18:40:27  Traceback (most recent call last):
18:40:29  Traceback (most recent call last):
18:40:41  Traceback (most recent call last):
18:40:42  Recompute failed! Please check report view.
OS: Debian GNU/Linux 10 (buster) (LXDE/LXDE-pi)
Version: 0.19.28143 (Git)
Build type: Unknown
Branch: LinkDaily
Hash: 44be6d539871be4083e83f428e8fcfbcf38408ef
Python version: 3.7.3
Qt version: 5.11.3
Locale: French/France (fr_FR)
gigax
Post by gigax »
-alex- wrote: Wed Sep 29, 2021 10:35 am
Agreed, I can replicate the same thing! Thanks!
Syres
Post by Syres »
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
I don't think so, you're still using 0.19.1, 0.19.2 is Git revision 0.19.24291 as per:
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24291 (Git)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
gigax
Post by gigax »
thanks Syres! I didn't realize there was a more recent release!
-alex-
Post by -alex- »
JFYI I was able to reproduce the issue with the very last release FC0.20 master.
FBXL5
Post by FBXL5 »
There are some differences between the command names in the GUI and names of each Python modules and the associated icons.
I'm using the GUI names for wiki descriptions and Roy_43 corrects it to match the module/icon names. We could save bit of work and time if the names would be matched.
Is it hard to change the Python modules? And add translatability at the same time?
I would like to help, but my Python skills are limited. Can I try it in my own environment somehow and (if I'm successful) later merge it for the next release?
Some of us ignore the fact that the SheetMetal workbench still isn't ready for translation and already work on the French and German translations. :roll:
