Sheet Metal Workbench
- thebighaggis
Re: Sheet Metal Workbench - Forming
Hi All
I've searched high and low with no luck Does anyone know how to use this tool? any videos? or a detailed description on how to use it..
OS: Linux Mint 20.2 (X-Cinnamon/cinnamon)
Version: 0.19.24291 (Git) AppImage
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: English/Australia (en_AU) Cheers
Haggis
Qt version: 5.12.9
OCC version: 7.4.0
Haggis
There is no proper tutorial available yet, but have a look at the wiki page (example at the bottom of the page).
https://wiki.freecadweb.org/SheetMetal_Forming
- papyblaise
you must imagine that you are driving the forme entirely into the sheet
So you select the face of the sheet, then the face of the forme that will be tangent to it
NB: if you modify the forme, the modification will be instantaneous (I add external conical face and smoll face on the midle) at forming1
- forming1.PNG (20.43 KiB) Viewed 2495 times
- forming.PNG (28.11 KiB) Viewed 2506 times
- forming.FCStd
- (33.35 KiB) Downloaded 55 times
- papyblaise
if you make a box with an emboss, you will not be able to unfold it, you have to remove this emboss, make it a common one and add it to the unfolded sheet
- emboss.FCStd
- (103.25 KiB) Downloaded 57 times
- emboss.PNG (49.69 KiB) Viewed 2460 times
This page needs some love...FBXL5 wrote: ↑Sun Sep 26, 2021 7:08 amThere is no proper tutorial available yet, but have a look at the wiki page (example at the bottom of the page).
With an active body it just fails. There is something else at play here.FBXL5 wrote: ↑Sun Sep 26, 2021 12:17 amThe tool works great with 0.20.
It seems like you have no active body.
The body containing the base plate (the face to be embossed) must be the active body. If it is not then double click on its representation in the tree view. It will be highlighted to show that it is active.
I think it is your Body002 that needs to be activated.
Select the planar face to receive the forming geometry.
Select the planar backside of your forming object.
Activate the Make Forming in Wall command
Have a look at the wiki page. I have tried my best to describe how to use this tool and put an example on the bottom of the page.
Please don't instruct me to RTFM...if you look, you'll notice I wrote the original wiki for SM.
I will be attempting to update the forming page later today. The descriptions of the tool operations are limited in detail. As is the tutorial you reference.
- thebighaggis
Thank you all
I'll have another go tomorrow..
Cheers
Haggis
Cheers
Haggis
https://forum.freecadweb.org/viewtopic. ... 80#p460676 and next poststhebighaggis wrote: ↑Sun Sep 26, 2021 6:48 am Does anyone know how to use this tool? any videos? or a detailed description on how to use it..
I wouldn't instruct you in that direction.
Hope you can live with my improvements. Let's give the pages some love together.
I'd like to shorten some of the older descriptions and rearrange bit more...
And I know my examples are not top notch, but they are better than nothing, I think. And when proper tutorials are available they should be removed.
Follow-up to previous posts...
Here, with Body002 (1mm Pad) if fails: The error displayed:
The Body objects all pass geometry check.
Sheet Metal V0.2.49
OS: Debian GNU/Linux 10 (buster) (XFCE/lightdm-xsession)
Version: 0.20.25844 (Git)
Hash: 1b20118dfa3fb9f127f0e4fb122701f7fcdaa9fc
Python version: 3.7.3
Qt version: 5.11.3
08:03:14 Traceback (most recent call last):
File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalFormingCmd.py", line 172, in execute
a = makeforming(tool, base, base_face, thk, tool_faces, offsetlist[i], fp.angle.Value)
File "/home/mac/.FreeCAD/Mod/sheetmetal/SheetMetalFormingCmd.py", line 114, in makeforming
offsetshell = tool.makeThickness(tool_faces, thk, 0.0001, False, False, 0, 0)
<class 'Part.OCCError'>: BRep_API: command not done
Sheet Metal V0.2.49
Qt version: 5.11.3
- FormingTool-1-1.FCStd
- (61.08 KiB) Downloaded 46 times
