Sheet Metal Workbench
janifr
Re: Sheet Metal Workbench
Post by janifr »
-alex- wrote: Mon Nov 08, 2021 10:45 pm But Unfold_Sketch_bends is empty now, only new Bendlines object is visible.
This is now fixed https://github.com/janifr/FreeCAD_Sheet ... db144b4dc1
Edit:
Fixed the other issues as well. Can you try if it works?
https://github.com/janifr/FreeCAD_Sheet ... nfolder.py
TO DO:
-If possible, place new objects in separate container so that they don't mess up the treeview
-Modify bend label placements so that they don't overlap if they are close to each other, possibly in the middle of the bend line
-alex-
Post by -alex- »
janifr wrote: Tue Nov 09, 2021 9:16 am
sorry but I see no effect, Unfold_Sketch_bends is still empty.
Edit:
You added angle value in code, thanks for that, but angle value is still missing in bendtable. BTW K-factor in bendtable still seems wrong to me.
Other users can give it a try, any comments are welcome.
TO DO:
+1
+1 , IMHO that would be great if the label was something like this: BENDnb-RADIUS-DIRECTION-ANGLE-Kfactor, ie. N1-R2-UP-90°-K=0.35
OS: Debian GNU/Linux 10 (buster) (LXDE/LXDE-pi)
Version: 0.20.26326 (Git)
Build type: Unknown
Hash: 2cc570757144422a189b9881e650c3878ec58b13
Python version: 3.7.3
Qt version: 5.11.3
Locale: French/France (fr_FR)
janifr
Post by janifr »
-alex- wrote: Tue Nov 09, 2021 8:08 pm
Thats odd, works here. I suspect there went something wrong with github download. Could you send me your SheetMetalUnfolder.py? I attached a file, if you could try it. If it still doesn't work I'm confused.
-alex- wrote: Tue Nov 09, 2021 8:08 pm OS: Debian GNU/Linux 10 (buster) (LXDE/LXDE-pi)
Build type: Unknown
Qt version: 5.11.3
I have different version, could that be the culprit?
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Finnish/Finland (fi_FI)
test_sheet_metal_bendtable_unfolder.FCStd
(24.94 KiB) Downloaded 55 times
(137.17 KiB) Downloaded 60 times
-alex-
Post by -alex- »
janifr wrote: Wed Nov 10, 2021 4:24 am I suspect there went something wrong with github download.
Yes I suspected that as well because I'm not familiar with git stuffs. BTW I didn't git clone your repo, I used the raw copy button on github then I pasted the to replace the previous content of my sheetmetalunfolder.py file.
I assume it had to work but... maybe my bad :?
Anyway, I used your file here linked and it works like a charme on Win system :D
I'll try again on Linux system later.
There is an issue though: "new" bend notes and bendlines objects are not oriented the same way with unfold sketch objects, so that notes don't mach with unfold sketches.
Your job is promising, much appeciated, keep forward :)
janifr
Post by janifr »
-alex- wrote: Wed Nov 10, 2021 8:26 am There is an issue though: "new" bend notes and bendlines objects are not oriented the same way with unfold sketch objects, so that notes don't mach with unfold sketches.
This is true, new bend lines seem as mirrored lines from sketch. This is something that should be corrected, but need to think a smart way to do it. Best thing would be if there was a way to incorporate bend line indexes to the original sketch. Another option could be automatic generation of cross section views. Both options render obsolete extra object we currently create.
-alex- wrote: Wed Nov 10, 2021 8:26 am Your job is promising, much appeciated, keep forward :)
Thank you for your kind words. I'll try to do my best.
-alex-
Post by -alex- »
janifr wrote: Wed Nov 10, 2021 4:40 pm Best thing would be if there was a way to incorporate bend line indexes to the original sketch.
+1
jaisejames
Post by jaisejames »
sfgrayson wrote: Thu Nov 04, 2021 3:03 am Hi,
Is there a way to make the Extend feature still work when not passing through a wall? It works perfectly fine as long as it is going through, but when the respective line is deleted in the base sketch, the extend feature breaks.
This would be very useful for making custom shaped flanges/tabs in general without making a bunch of additional PartDesign features on the Extend.
Great job on the workbench devs, I'm having a blast learning it. I use CAD everyday at work to design chimney parts so I'm very excited to bring FreeCAD into that work and for other sheetmetal workers.
Bug fix push to git.
https://github.com/shaise/FreeCAD_SheetMetal/pull/215
pls test it, if it is working properly.
sfgrayson
Post by sfgrayson »
jaisejames wrote: Thu Nov 11, 2021 6:33 am
Screenshot from 2021-11-11 21-58-18.png (58.69 KiB) Viewed 2832 times
I will definitely use it more and see but initial testing shows it works very well. This is a gamechanger for certain workflows with lots of flanges/flanges with specific cutouts. For example, in the chimney business we laser-cut rivet holes to make caps and shrouds :D
Thank you!
ExtendTest.FCStd
(37.25 KiB) Downloaded 67 times
FBXL5
Post by FBXL5 »
jaisejames wrote: Thu Nov 11, 2021 6:33 am pls test it, if it is working properly.
I tried it and it seems to work properly.
A profile with extension sketch:
Result plus another extension sketch (btw - sketch is attached to the original profile):
The extended extension works well (subtraction enabled):
But one thing puzzles me: How can I build this from sheet metal? ;) :D
papyblaise
Post by papyblaise »
cut the small bridge , bend , reflat , and weld ;)
how to do.PNG (27.13 KiB) Viewed 2603 times
