Exporting files
Exporting files
I have a donut with text inscribed in it. I select the cut and export to a step file. When I open the step file the text is filled.
Can anyone tell what is wrong?
Regards,
Joe K.
OS: Windows 10 (10.0)
Version: 0.19.23756 (Git)
Hash: 9c6e9184930a52b165a0b7274e3a45d1006bfe67
Python version: 3.6.8
Qt version: 5.12.1
Regards,
Joe K.
Qt version: 5.12.1
- RingSizer10.FCStd
- FCStd of donut w/ 10 cut into it.
- (56.05 KiB) Downloaded 37 times
- Ring Sizer 10.step
- step file of donut
- (241.51 KiB) Downloaded 37 times
Re: Exporting files
Please read the documentation: Std_Export.
Specifically the selection instructions.
Re: Exporting files
Confirmed. I don't think you did anything wrong.
OS: macOS 10.16
Version: 0.20.25311 (Git)
Hash: c5524bb58a7126fa2242d6137eb82ee9d54e82d4
Python version: 3.9.6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
Re: Exporting files
Rotate the circle sketch so that the seamline does not intersect the cut, and then do the export again.
Select sketch -> edit menu -> placement -> check apply incremental changes -> check use center of mass -> set y for axis -> rotate 90 degrees
- thomas-neemann
Re: Exporting files
apparently something is wrong with the fcstd file. realthunder throws an error message when opening.
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 2021.717.24301 +3627 (Git) AppImage
Branch: LinkStage3
Hash: f63a5ea7b459872a3798027df0ff25e776524859
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
Re: Exporting files
That says nothing about the issue discussed here. Read the message: it says the font file is missing.thomas-neemann wrote: ↑Wed Aug 04, 2021 9:08 pm apparently something is wrong with the fcstd file. realthunder throws an error message when opening.
- thomas-neemann
Re: Exporting files
ok, can you say that a freecad file can only be processed further on the operating system on which it was created? (If the question doesn't fit here, I could open a new topic.)
Re: Exporting files
Not in general, but fonts are not included in the file for license reasons. I have proposed a long time ago to allow at least relative paths for them. Then I could just send a project folder containing model plus fonts to another system an it would work there.thomas-neemann wrote: ↑Thu Aug 05, 2021 6:08 am ok, can you say that a freecad file can only be processed further on the operating system on which it was created? (If the question doesn't fit here, I could open a new topic.)
- thomas-neemann
Re: Exporting files
it seems to work with a linux font
lg thomas
lg thomas
Re: Exporting files
Greetings to the Community!
I describe my experimentation:
- I imported the "Ring Sizer 10.step" file (the original one attached to the topic) into another cad and it was imported correctly (with the number 10 hollowed in the ring).
- From a cad (not FC) I exported “Ring Sizer 10” again in * .step format, renaming it to “Ring Sizer 10-2.step”, it went from a source weight of 242 kb to 97 kb.
- I tried to import "Ring Sizer 10-2.step" into FC without success because FC never stops importing the file and I was forced, after a long time, to kill the import.
- Even the original file, "Ring Sizer 10.step", I can't import it into FC and I'm forced to kill the import, I don't want to wait all day in front of the monitor.
Since the other cad takes a few tenths of a second to import the two files, I believe that the latest FC updates have, with all probability, compromised the code that implies the import / opening of the * .steps; does anyone know of this eventuality?
I attach the file "Ring Sizer 10-2.step" exported with other cad with the hope that someone will be able to import it in a version of FC different from mine:
OS: Windows 8 (6.2)
Version: 0.20.25334 (Git)
Hash: 433c52c290681992346b6cda6482bf6a73d74e25
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
Locale: Italian/Italy (it_IT)
OS: Windows 8 (6.2)
Qt version: 5.12.9
OCC version: 7.5.2
- Ring Sizer 10-2.step
- (96.58 KiB) Downloaded 30 times
