[Solved] One transformed shape does not intersect support-create polar pattern tool
rek
Re: [Solved] One transformed shape does not intersect support-create polar pattern tool
Post by rek »
TheMarkster wrote: Sat Oct 16, 2021 4:33 am It has failed as the other has failed and for the same reason. The polar array elements must all intersect material from the same body. It matters not that the elements intersect material from another Body. Each Body must be a single contiguous solid at every step of the process.
boom! I reed that loud and clear. The warning message should add your line "Each Body must be a single contiguous solid" to it. Whenever possible, error messages should contain enough clues for an user to understand why the function could not be performed.
And thanks for the other tip Chrisb, I was thinking maybe a mirror function would help but that would cause the same problem. I will experiment with the other mode you mentioned. I read your sketcher tutorial pdf, I hope you find the inspiration to keep going with that since it's a work in progress and I hope it inspires more pdfs of that same level of detail.
rek wrote: Sat Oct 16, 2021 12:31 pm I read your sketcher tutorial pdf, I hope you find the inspiration to keep going with that since it's a work in progress and I hope it inspires more pdfs of that same level of detail.
Thanks for the kind words. I'm currently working on an introductory document to FreeCAD. Pheew, quite a difficult task.
