Hey,
Is there a way to make this export to PDF sharper and cleaner see attachments,
thanks in advance!
Greetz Wouter
export draft to PDF
export draft to PDF
- Zolder plattegrond 2D stopcontacten test123.FCStd
- (157.94 KiB) Downloaded 20 times
- kak1.pdf
- (45.49 KiB) Downloaded 37 times
Re: export draft to PDF
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Dutch/Belgium (nl_BE)
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
How exactly did you create those things? They look like imported Techdraw geometry... Thy not export directly from Techdraw?
- thomas-neemann
is it that sharp and clean enough?
Greetings Thomas
Beste Walterschurk,
In this Draft design of you the text get hard to read after exporting to PDF.
I imported the Draft map you labeled Techdraw in a Techdraw page. The texts get lost now.
I wrote the texts again with Techdraw annotations.
An export of this PDF is of a good quality
- kak2.pdf
- (75.33 KiB) Downloaded 11 times
- Zolder plattegrond 2D stopcontacten.FCStd
- (161.5 KiB) Downloaded 10 times
Hey,
It is good now thanks for the responses
Greetz Wouter
Greetz Wouter
