outdoor staircase
Lim
outdoor staircase
Post by Lim »
may I ask if anyone here can help to draw a straight 10 feet concrete outdoor staircase ?
with one middle landing on an existing small column ?
Warmest regards
LIM
papyblaise
Re: outdoor staircase
Post by papyblaise »
voilà
step.FCStd
(13.62 KiB) Downloaded 27 times
kisolre
Post by kisolre »
Any additional info? Step height, offsets from start to the end, column location and shape? Should it include reinforcements, drawings, ...?Do you just want the job done or also want to learn some FreeCAD along the way?
thomas-neemann
Post by thomas-neemann »
papyblaise wrote: Fri Aug 27, 2021 10:30 amvoilà
Did you draw all stages individually, or is there an automatism after the 1st stage in the sketcher?
ich biete freecad online-support an, als mini-job
VHS Freecad Aufbaukurs
https://www.vhs-lingen.de/programm/beru ... 012#inhalt
my workflow is optimized for speed, not for parametric
If you want regular repititions, then it is done with a pattern (PartDesign) or a Draft array (Part).
thomas-neemann
chrisb wrote: Fri Aug 27, 2021 11:24 am If you want regular repititions, then it is done with a pattern (PartDesign) or a Draft array (Part).
thanks for the information. does something like that make sense for the sketcher, so that the constraints are set right away?
There are several threads discussing this (recurring) topic. The pros here rather recommend to stick to simple sketches and add complexity outside of sketcher.
E.g. in Pro/E was the 7-7-7 rule promoted:
- a sketch should have no more than 7 elements
- or no more than 7 measures
- or take no longer than 7 minutes to be completed (fully constrained)
I would second this: The sketches are the most important things to think about, so keep them as simple as possible.
thomas-neemann
chrisb wrote: Fri Aug 27, 2021 12:12 pm
that sounds sensible, but can you make an extrude with several sketches?
thomas-neemann wrote: Fri Aug 27, 2021 12:15 pm can you make an extrude with several sketches?
No, but you can fuse the extrudes made from several sketches.
thomas-neemann
chrisb wrote: Fri Aug 27, 2021 12:23 pm
that's how I do it too. if you use the advantages of the sketcher, e.g. kinematics, from draft e.g. array, 3d sketches and from part e.g. multiple bodies, then you have a very powerful cad system
