[solved] View section opposite direction? (sketcher)
- thomas-neemann
if you are working in a mirrored sketch, it would make sense to reverse the direction of view section. i can't do it. is there a possibility?
Greetings Thomas
Greetings Thomas
Last edited by thomas-neemann on Mon Aug 30, 2021 8:59 pm, edited 2 times in total.
- thomas-neemann
Re: View section opposite direction? (sketcher)
i could imagine that a modified python line could bring the result.
ActiveSketch.ViewObject.TempoVis.sketchClipPlane(ActiveSketch)
If you want to work from behind, you should set MapReversed=True.
- papyblaise
you can't do the symmetry of the sketch, but on the other hand
if you are in Partdesign, he will not want to create 2 separate parts in the same body
in PartWb it will work
Hello
... I don't know if this topic could be for you https://forum.freecadweb.org/viewtopic. ... &start=30
- thomas-neemann
in this case you can create the mirror image with it, but the display in view section is unchanged
I work in the part wb
I tested something like that with a cut view, but as soon as you switch to the sketcher, sketcher has its own view
as long as there is no solution, I would have to offer a workaround:
https://www.youtube.com/watch?v=L7LiCxryYPQ
Greetings Thomas
OS: Ubuntu 20.04.1 LTS (XFCE/xubuntu)
Version: 2021.717.24301 +3627 (Git) AppImage
Branch: LinkStage3
Hash: f63a5ea7b459872a3798027df0ff25e776524859
Python version: 3.9.6
Qt version: 5.12.9
Coin version: 4.0.1
OCC version: 7.5.2
.... this update has arrived now now, it is the macro of aleph0 revised and corrected https://forum.freecadweb.org/viewtopic. ... &start=30 (I haven't tried it yet)
- thomas-neemann
thanks. it works. Marvelousdomad wrote: ↑Mon Aug 30, 2021 8:40 pm.... this update has arrived now now, it is the macro of aleph0 revised and corrected https://forum.freecadweb.org/viewtopic. ... &start=30 (I haven't tried it yet)
You have a solution now, but I would like to understand this. With MapReversed=True the sketch plane is opened from behind. And you say that the section is now in front of the sketch plane?thomas-neemann wrote: ↑Mon Aug 30, 2021 6:42 pmin this case you can create the mirror image with it, but the display in view section is unchanged
- thomas-neemann
