Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
keithsloan52
Post by keithsloan52 »
Chris Hennes @chennes is building up a number of test cases for the OpenSCAD workbench.
We also need a central point where people can post problem files.
So if you have any problem scad or csg files that correctly load in OpenSCAD but fail to import correctly, please post and add the files to this thread, Thanks
P.S. If an admin would pin this post that would also be great.
GeneFC
Re: Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
Post by GeneFC »
Pinned, but should be reviewed and pin removed when no longer needed.
astrojhgu
Post by astrojhgu »
https://forum.freecadweb.org/viewtopic.php?f=3&t=61831
I have met a potential bug. It seems that linear_extrude is not working correctly in FreeCAD.
A desired model is correctly created but not correctly rendered. A subtracted part is set to be visible.
keithsloan52
astrojhgu wrote: Mon Sep 06, 2021 3:29 am https://forum.freecadweb.org/viewtopic.php?f=3&t=61831
As per the linked thread, it is fixed in FreeCAD 0.20 or if using the alternate importer https://github.com/KeithSloan/OpenSCAD_Alt_Import
Or are you still having problems?
astrojhgu
Post by astrojhgu »
Thanks.
I have not yet tested the new version for my nixos repository has not been upgraded.
keithsloan52 wrote: Mon Sep 06, 2021 6:58 am
kwahoo
Post by kwahoo »
It seems that an object rotation is not preserved if the object is exported as a polyhedron.
Take look at this example, Body is rotated by 90 deg around X axis:
This happens for placement applied on the shape directly (eg. by Python scripting). Translation is preserved. Edit: tested with another file and translation seems to be applied twice (first time in multmatrix and then directly in polyhedron points coordinates)?
OS: Ubuntu Impish Indri (development branch) (KDE/plasma)
Version: 0.20.
Branch: unknown
Hash: 12d0974525afe812e81ad623f7d915cb1784118e
Python version: 3.9.6
Qt version: 5.15.2
OCC version: 7.5.2
Locale: Polish/Poland (pl_PL)
platetest.FCStd
(9.49 KiB) Downloaded 31 times
platetest-Kostka.scad
(8.34 KiB) Downloaded 25 times
keithsloan52
kwahoo wrote: Tue Sep 14, 2021 1:23 pm Hi,
Sorry I am confused.
If I load the scad file into OpenSCAD the long side is on the X axis, same if I import into FreeCAD, what am I missing?
OS: macOS 10.15
Version: 0.20.25566 (Git)
Hash: 8c361dd3fc83840a911da950a845eb9f9342a0b6
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
kwahoo
Post by kwahoo »
keithsloan52 wrote: Sun Sep 19, 2021 9:15 pm
It is rotated around X on my screenshot. It "lays flat" on the XZ plane in FreeCAD and XY plane in OpenSCAD.
keithsloan52
kwahoo wrote: Tue Sep 21, 2021 6:59 pm
Still not getting it.
For me in OpenSCAD the largest surface is in the X-Y plane and has a negative thickness in the Z direction
OpenSCAD is version 2021.01
This is what it looks like in FreeCAD with a default cube added.
i.e. Again largest surface in the X-Y plane and negative in the Z direction
kwahoo
Post by kwahoo »
keithsloan52 wrote: Tue Sep 21, 2021 7:54 pm
Ok, It is indeed in the X-Y local plane of Body, but also in the X-Z global plane according the gizmo in the corner. (planes differ, because the Body is rotated)
This is screenshot with the default cube moved by 50 mm in the Z direction:
So, does the exporter use local (inside the Body) coordinates only? Preserving global coordinates would be very useful for assemblies.
