Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
chennes
Re: Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
Post by chennes »
I can fix the visibility issue with the stairs by re-writing the fixVisibility() function, but I'm not sure if this has negative consequences outside of this case, since I don't really understand the heuristics that were being used in the old one. @keithsloan52, can you have a look at this and make sure it's doing what you intended that function to do? The new version is quite a lot simpler because it relies on FreeCAD's internal "rootObject" notion, and the idea that coming out of the OpenSCAD converter, anything under a root object should be hidden. Obviously a real solution will have to cope with objects that weren't imported from OpenSCAD, but this is the core idea of the fix:
def fixVisibility():
    for root_object in FreeCAD.ActiveDocument.RootObjects:
        root_object.ViewObject.Visibility=True
        for obj in root_object.OutListRecursive:
            obj.ViewObject.Visibility=False
keithsloan52 wrote: Wed Dec 15, 2021 3:45 pm Ping
Chris Hennes
Pioneer Library System
keithsloan52
Post by keithsloan52 »
Hi Chris
Happy New Year
chennes wrote: Tue Jan 11, 2022 4:42 am I can fix the visibility issue with the stairs by re-writing the fixVisibility() function, but I'm not sure if this has negative consequences outside of this case, since I don't really understand the heuristics that were being used in the old one. @keithsloan52, can you have a look at this and make sure it's doing what you intended that function to do? The new version is quite a lot simpler because it relies on FreeCAD's internal "rootObject" notion, and the idea that coming out of the OpenSCAD converter, anything under a root object should be hidden. Obviously a real solution will have to cope with objects that weren't imported from OpenSCAD, but this is the core idea of the fix:
By original fixVisibility I assume you mean
    for obj in FreeCAD.ActiveDocument.Objects:
         if(( obj.TypeId=="Part::Fuse" or obj.TypeId=="Part::MultiFuse") and shallHide(obj)):
            if "Group" in obj.FullName:
                alreadyhidden.append(obj)
                for currentObject in obj.OutList:
                    if(currentObject not in alreadyhidden):
                        currentObject.ViewObject.Visibility=True
Although it is in importCSG which has my copyright its not something I recognise could have been added by Sebastian.
I would go with your update.
I also note that the original code is followed by if gui: surely the whole thing should be subject to an if gui:
Keith
chennes
Post by chennes »
keithsloan52 wrote: Tue Jan 11, 2022 8:33 am I also note that the original code is followed by if gui: surely the whole thing should be subject to an if gui:
Thanks for checking, I didn't bother with a git blame, but it doesn't really matter, I'm pretty confident this is what the old function was trying to do. It's only called once, inside an if_gui clause, so we could define the function only in an if_gui as well, but Python being Python, it doesn't actually matter much. I don't know why it's at the top of the file... I usually bury these "cheater" functions at the bottom!
Chris Hennes
chennes
Post by chennes »
OK, git commit 1f70e352a modifies that "fix", and I now get the correct output for that ladder. I spot checked a few other OpenSCAD files I had sitting around and didn't see any regressions, but please report them here if you run across any.
Chris Hennes
bvwj
Post by bvwj »
I can bite out the corner of this square with difference, or I can round the corners with offset. Alone either work.
When I try to difference the corner, then round with offset, it fails.
$fn=64;
linear_extrude(2)
  offset(r = 2)
    difference(){
      square([20, 20],center=true);
      translate([10,10])
        circle(d = 10);
File "/Applications/FreeCAD.app/Contents/Resources/Mod/OpenSCAD/importCSG.py", line 432, in p_offset_action
    if subobj[0].Shape.Volume == 0 :
<class 'RuntimeError'>: shape is invalid
OS: macOS 10.16
Version: 0.19.24291 (Git)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
bvwj
Post by bvwj »
Is the difference/offset/extrude method something that should work in FreeCAD, or is it off limits?
I like this method to generate printed circuit board outlines with radiused corners. It is a practical application, not just an interesting structure.
If it will not work I need to go back to adding all the fillets and rounding corners one at a time so I can get these boards into FreeCAD to design the rest of the housing.
chennes
Post by chennes »
I was able to reproduce your error in the latest build of FreeCAD, but I have not had time to debug it (and probably won't for a few weeks). I don't see any obvious reason why it doesn't work, but maybe @keithsloan52 has some idea.
keithsloan52 wrote: Tue Jan 11, 2022 8:33 am .
Chris Hennes
keithsloan52
chennes wrote: Thu Jan 27, 2022 10:53 pm I was able to reproduce your error in the latest build of FreeCAD, but I have not had time to debug it (and probably won't for a few weeks). I don't see any obvious reason why it doesn't work, but maybe @keithsloan52 has some idea.
Adding to the code
    print(f'p6 : {p[6]}')
    print(dir(p[6]))
Report View looks like
09:45:46  ImportCSG Version 0.6a
09:45:46  Start Lex
09:45:46  End Lex
09:45:46  Load Parser
09:45:46  Parser Loaded
09:45:46  Start Parser
09:45:46  ('height', '2')
09:45:46  ('center', 'false')
09:45:46  ('convexity', '1')
09:45:46  2d Point
09:45:46  ('scale', [1.0, 1.0])
09:45:46  ('$fn', '64')
09:45:46  ('$fa', '12')
09:45:46  ('$fs', '2')
09:45:46  ('r', '2')
09:45:46  2d Point
09:45:46  ('size', [20.0, 20.0])
09:45:46  ('center', 'true')
09:45:46  Square
09:45:46  Vector
09:45:46  Vector
09:45:46  Vector
09:45:46  Vector
09:45:46  Matrix
09:45:46  ('r', '5')
09:45:46  Circle : {'$fn': '64', '$fa': '12', '$fs': '2', 'r': '5'}
09:45:46  Circle Shape : True
09:45:46  Push Circle
09:45:46  MultMatrix
09:45:46  Multmatrix
09:45:46  [['1', '0', '0', '10'], ['0', '1', '0', '10'], ['0', '0', '1', '0'], ['0', '0', '0', '1']]
09:45:46  Matrix ((1,0,0,10),(0,1,0,10),(0,0,1,0),(0,0,0,1))
09:45:46  Apply Multmatrix
09:45:46  special orthogonal
09:45:46  rotation rounded
09:45:46  [<Part::Part2DObject>]
09:45:46  difference
09:45:46  2
09:45:46  [<Part::PartFeature>, <Part::Part2DObject>]
09:45:46  Push Resulting Cut
09:45:46  End Cut
09:45:46  p6 : [<Part::PartFeature>]
09:45:46  ['__add__', '__class__', '__contains__', '__delattr__', '__delitem__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__getitem__', '__gt__', '__hash__', '__iadd__', '__imul__', '__init__', '__init_subclass__', '__iter__', '__le__', '__len__', '__lt__', '__mul__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__reversed__', '__rmul__', '__setattr__', '__setitem__', '__sizeof__', '__str__', '__subclasshook__', 'append', 'clear', 'copy', 'count', 'extend', 'index', 'insert', 'pop', 'remove', 'reverse', 'sort']
09:45:46  Traceback (most recent call last):
  File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/freecad/OpenSCAD_Alt_Import/importCSG.py", line 96, in open
    processcsg(tmpfile)
  File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/freecad/OpenSCAD_Alt_Import/importCSG.py", line 157, in processcsg
    result = parser.parse(f.read())
  File "/Applications/FreeCAD_19.2.app/Contents/Resources/lib/python3.8/site-packages/ply/yacc.py", line 333, in parse
    return self.parseopt_notrack(input, lexer, debug, tracking, tokenfunc)
  File "/Applications/FreeCAD_19.2.app/Contents/Resources/lib/python3.8/site-packages/ply/yacc.py", line 1120, in parseopt_notrack
    p.callable(pslice)
  File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/freecad/OpenSCAD_Alt_Import/importCSG.py", line 411, in p_offset_action
subobj = p6
So the code assumes it is dealing with an Object with a Shape where as in this case it is being passed a <Part::PartFeature> and it does not have a Shape. It looks like what is passed is the result of the cut.
Might have more time to look this evening
keithsloan52
Adding debug code to the difference i.e. cut the Push of the result looks okay
10:04:26  difference
10:04:26  2
10:04:26  [<Part::PartFeature>, <Part::Part2DObject>]
10:04:26  Push Resulting Cut
10:04:26  ['Base', 'Content', 'Document', 'ExpressionEngine', 'FullName', 'History', 'ID', 'InList', 'InListRecursive', 'Label', 'Label2', 'MemSize', 'Module', 'MustExecute', 'Name', 'NoTouch', 'OldLabel', 'OutList', 'OutListRecursive', 'Parents', 'Placement', 'PropertiesList', 'Refine', 'Removing', 'Shape', 'State', 'Tool', 'TypeId', 'ViewObject', 'Visibility', '__class__', '__delattr__', '__dir__', '__doc__', '__eq__', '__format__', '__ge__', '__getattribute__', '__gt__', '__hash__', '__init__', '__init_subclass__', '__le__', '__lt__', '__ne__', '__new__', '__reduce__', '__reduce_ex__', '__repr__', '__setattr__', '__sizeof__', '__str__', '__subclasshook__', 'addExtension', 'addProperty', 'adjustRelativeLinks', 'dumpContent', 'dumpPropertyContent', 'enforceRecompute', 'evalExpression', 'getAllDerivedFrom', 'getDocumentationOfProperty', 'getEditorMode', 'getEnumerationsOfProperty', 'getGlobalPlacement', 'getGroupOfProperty', 'getLinkedObject', 'getParentGeoFeatureGroup', 'getParentGroup', 'getPaths', 'getPathsByOutList', 'getPropertyByName', 'getPropertyNameOfGeometry', 'getPropertyOfGeometry', 'getPropertyStatus', 'getPropertyTouchList', 'getStatusString', 'getSubObject', 'getSubObjectList', 'getSubObjects', 'getTypeIdOfProperty', 'getTypeOfProperty', 'hasChildElement', 'hasExtension', 'isDerivedFrom', 'isElementVisible', 'isValid', 'purgeTouched', 'recompute', 'removeProperty', 'resolve', 'resolveSubElement', 'restoreContent', 'restorePropertyContent', 'setEditorMode', 'setElementVisible', 'setExpression', 'setPropertyStatus', 'supportedProperties', 'touch']
10:04:26  End Cut
10:04:26  p6 : [<Part::PartFeature>]
So clearly something is not right as this is what the 2DOffset should see
keithsloan52
Error in Offset Action
The current code expects the object to be offset to have a valid Shape, where as in this case it is a Part::Cut with just a Base and Tool Objects
I have tried to change the difference/cut code to create a Shape from the Base and Tool but I then hit the problem that in this case the Tool is a circle created with
mycircle = FreeCAD.ActiveDocument.addObject("Part::Part2DObjectPython",'circle')
        Draft._Circle(mycircle)
        mycircle.Radius = r
        mycircle.MakeFace = True
        #mycircle = Draft.makeCircle(r,face=True) # would call doc.recompute
        #mycircle = doc.addObject('Part::Circle',p[1]) #would not create a face
        #mycircle.Radius = r
        print('Circle Shape : ' +str(mycircle.Shape.isNull()))
And this prints out that the circle shape is a Null i.e. does not have a valid Shape
@chennes any ideas?
