Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
keithsloan52
Re: Problem OpenSCAD scad & csg files - PLEASE Add them to this thread - Thanks
Post by keithsloan52 »
bvwj wrote: Mon Feb 07, 2022 9:01 pm This is the error trace when I import with importCSG.py.
14:00:00 WARNING: Token 'DOT' defined, but not used
14:00:00 WARNING: Token 'WORD' defined, but not used
14:00:00 WARNING: There are 2 unused tokens
14:00:00 Traceback (most recent call last):
File "/Applications/FreeCAD.app/Contents/Resources/Mod/OpenSCAD/importCSG.py", line 130, in open
processcsg(tmpfile)
File "/Applications/FreeCAD.app/Contents/Resources/Mod/OpenSCAD/importCSG.py", line 191, in processcsg
result = parser.parse(f.read())
File "/Applications/FreeCAD.app/Contents/Resources/lib/python3.8/site-packages/ply/yacc.py", line 333, in parse
return self.parseopt_notrack(input, lexer, debug, tracking, tokenfunc)
File "/Applications/FreeCAD.app/Contents/Resources/lib/python3.8/site-packages/ply/yacc.py", line 1120, in parseopt_notrack
p.callable(pslice)
File "/Applications/FreeCAD.app/Contents/Resources/Mod/OpenSCAD/importCSG.py", line 659, in p_difference_action
mycut.Shape = mycut.Base.Shape.cut(mycut.Tool.Shape)
<class 'Part.OCCError'>: Tool shape is null
The recomputes of the twist_extrudes are failing for some reason
21:44:19  Processing : /Users/keithsloan/MEGA/MEGAsync/CAD_Files/OpenSCAD/testFiles/bvwj.scad
21:44:19  Calling OpenSCAD
21:44:19  Using Alternate OpenSCAD Importer
21:44:19  Object cube Check Object Shape
21:44:19  Object twist_extrude Check Object Shape
21:44:19  19Standard_NullObject Traceback (most recent call last):
  File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/OpenSCADFeatures.py", line 404, in execute
    self.createGeometry(fp)
  File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/OpenSCADFeatures.py", line 412, in createGeometry
    if fp.Base and fp.Height and fp.Base.Shape.isValid():
<class 'Part.OCCError'>: 19Standard_NullObject
21:44:19  Recompute failed
21:44:19  Traceback (most recent call last):
  File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/freecad/OpenSCAD_Alt_Import/importCSG.py", line 96, in open
    processcsg(tmpfile)
  File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/freecad/OpenSCAD_Alt_Import/importCSG.py", line 157, in processcsg
  File "/Applications/FreeCAD_19.2.app/Contents/Resources/lib/python3.8/site-packages/ply/yacc.py", line 333, in parse
  File "/Applications/FreeCAD_19.2.app/Contents/Resources/lib/python3.8/site-packages/ply/yacc.py", line 1120, in parseopt_notrack
    p.callable(pslice)
  File "/Users/keithsloan/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/freecad/OpenSCAD_Alt_Import/importCSG.py", line 699, in p_difference_action
@chennes Chris I think you did some work on extrudes perhaps you could look at.
I have pushed the updates outputting details on recompute to https://github.com/KeithSloan/OpenSCAD_Alt_Import
chennes
Post by chennes »
That last example loads fine for me with the last changes you made, Keith:
Chris Hennes
Pioneer Library System
keithsloan52
chennes wrote: Mon Feb 07, 2022 10:06 pm That last example loads fine for me with the last changes you made, Keith:
Thanks Chris, I think the OpenSCAD_Alt_importer probably does not have the fixes you did for extrude a while back so that would explain why it is failing for me.
bvwj
Post by bvwj »
I added the new importCSG.py to this:
OS: macOS 10.16
Version: 0.19.24291 (Git)
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
Locale: C/Default (C)
keithsloan52
bvwj wrote: Mon Feb 07, 2022 10:53 pm I added the new importCSG.py to this:
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.4.0
So it is now working for you? Not clear to me from your post.
bvwj
Post by bvwj »
I was just trying to answer your previous question. No it is still not working.
I just downloaded the new importCSG.py. I still get these errors trying to import the example of the connector hole in the plate.
Are there other FreeCAD upgrades that I need?
09:02:48 Processing : /Users/barry/Projects/OpenSCAD/PCB/test4.scad
09:02:48 Using Alternate OpenSCAD Importer
09:02:48 19Standard_NullObject Traceback (most recent call last):
File "/Users/barry/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/OpenSCADFeatures.py", line 404, in execute
File "/Users/barry/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/OpenSCADFeatures.py", line 412, in createGeometry
09:02:48 Traceback (most recent call last):
File "/Users/barry/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/freecad/OpenSCAD_Alt_Import/importCSG.py", line 125, in insert
processcsg(tmpfile)
File "/Users/barry/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/freecad/OpenSCAD_Alt_Import/importCSG.py", line 157, in processcsg
p.callable(pslice)
File "/Users/barry/Library/Preferences/FreeCAD/Mod/OpenSCAD_Alt_Import/freecad/OpenSCAD_Alt_Import/importCSG.py", line 696, in p_difference_action
keithsloan52
bvwj wrote: Tue Feb 08, 2022 4:05 pm I was just trying to answer your previous question. No it is still not working.
processcsg(tmpfile)
p.callable(pslice)
Are you using the Alternate Importer or vanilla?
I made an error updating OpenSCAD_Alt_Import/OpenSCADFeatures sorry about that, should now be fixed.
If you are using the main FreeCAD OpenSCAD importer you need to get the latest importCSG.py and OpenSCADFeatures.py from the main github repository
bvwj
Post by bvwj »
Thanks for the fix. The Alternate Importer now works fine on my most complicated design!
I updated both importCSG.py and OpenSCADFeatures.py and still get the same errors when trying to use the regular importer.
Screen Shot 2022-02-08 at 10.15.24 AM.png (211.21 KiB) Viewed 3217 times
keithsloan52
bvwj wrote: Tue Feb 08, 2022 5:16 pm Thanks for the fix. The Alternate Importer now works fine on my most complicated design!
@chennes Hi Chris I think there is in the main repro still one CheckObjShape missing from importCSG.py
but maybe not if it works for you
chennes
Post by chennes »
Entirely possible one is missing, I did the merge purely by hand, by reading your diffs. Do you happen to know which one it is that I missed?
Chris Hennes
