Getting solid out of compound
hellsing48
Post by hellsing48 »
Hello everyone,
I'm am new to FreeCad and I am trying to get the solid out of this shape:
I tried making the box around it (bellow) and tried differnt ways to cut it using "Cutout for object", "Slice appart", "Make a cut of two shapes" but noting wokred.
Next I also tried to close the volume using boxes in order to get something like a shell and than use Part/Convert to solid option but that also didn't work out.
Is there any way to do it sucessfuly?
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
hull.FCStd
(530.17 KiB) Downloaded 21 times
hellsing48
Re: Getting solid out of compound
I am still looking for a way to do this.
Any advice can be helpful.
heda
Post by heda »
use surface wb to "fill the holes", then part wb to go from a watertight shell to a solid (partbuilder).
hellsing48
Thank you very much for answering. This is exactly what I am looking for!
I used "Filling" option to successfully cover the top.
However I'm struggling to do the same for the front side. Seems like it manages to cover only part of it.
Do you have any advice how to deal with this?
hull_topClosed.FCStd
(1002.36 KiB) Downloaded 16 times
hellsing48
heda wrote: Sun Sep 05, 2021 3:02 pm use surface wb to "fill the holes", then part wb to go from a watertight shell to a solid (partbuilder).
Ok I managed to fully close it with adding some additional lines.
Can you explain in a bit more details the second part, transforming to solid? How to go from a watertight shell to a solid?
kisolre
Post by kisolre »
hellsing48
kisolre wrote: Sun Sep 05, 2021 5:26 pm Part/Convert to solid
That is what I was trying to do. However I get the following error message:
19:47:22 Traceback (most recent call last):
File "<string>", line 2, in <module>
<class 'Part.OCCError'>: Shape is not a shell
19:47:22 Cannot convert Compound002 because Shape is not a shell.
Most likely it is because two surfaces can't be fully closed. Apparently the highlighted edge is causing the problem.
Any ideas how to deal with it? The file is attached.
Thank you for your help guys. This is really getting somewhere.
hull_closed1.FCStd
(881.62 KiB) Downloaded 20 times
TheMarkster
Post by TheMarkster »
I worked on this, but could never get a good solid that would pass check geometry before stopping.
If you zoom in really close you can see some issues where the edges are supposed to connect:
Snip macro screenshot-3208fc.png (15.66 KiB) Viewed 1320 times
I used lattice2 workbench downgrade to edges, explode compound to get that view.
I downgraded to faces in draft workbench, then part -> union on those faces. Somehow that magically fixed some of the gaps in some of the faces.
Snip macro screenshot-eb2628.png (36.83 KiB) Viewed 1316 times
hull_markster-Shell009 (Solid).zip
(214.25 KiB) Downloaded 20 times
hellsing48
Wow brilliant, thank you TheMarkster :D
Thank you all for the help.
kisolre
Post by kisolre »
Just out of curiosity - where did you get that shell from? Because the KCS_hull_SVA clearly has some problems...
