Taper and array
Taper and array
Please advise me on how I can taper this pad so that the top face is smaller than the bottom; an angle of 5 deg would be fine. Also, how can I array the loft cut to the other 3 corners?
- OBJECT001.PNG (9.89 KiB) Viewed 1461 times
- OBJECT001.FCStd
- (18.13 KiB) Downloaded 22 times
- thomas-neemann
Re: Taper and array
if it can be done with part and draft, i can make a video for you
- Shalmeneser
Re: Taper and array
└ Body (Body)
├ Pad (Pad)
│ └ Sketch (Sketch)
├ Chamfer (Chamfer)
└ Draft (Draft)
90/sqrt(2)
- OBJECT001_SHALM.FCStd
- (16.14 KiB) Downloaded 18 times
Re: Taper and array
Thank you, please do. I would like to know that method too.thomas-neemann wrote: ↑Wed Sep 08, 2021 8:36 pm if it can be done with part and draft, i can make a video for you
Re: Taper and array
Thank you for this. First time I have seen that draft tool in action.Shalmeneser wrote: ↑Wed Sep 08, 2021 8:41 pm * Chamfer :* PartDesign_DraftCode: Select all
90/sqrt(2)
Re: Taper and array
OK, FC can do a polar array of a loft cut!!! Fantastic. Just what I was hoping for
I am impressed with this software
- OBJECT001_SUCCESS.FCStd
- (27.63 KiB) Downloaded 21 times
- OBJECT001_POLARPAT_SUBLOFT.PNG (52.26 KiB) Viewed 1353 times
- Shalmeneser
Re: Taper and array
You should not Loft but Pocket.
- thomas-neemann
- papyblaise
Re: Taper and array
you can use an irregular octagon that you adjust 4 sides =, the other 4 with another equality
PartDesign does not allow it, but Part yes, you just have to leave 0.000 ... 001mm on the small sides
so you can't make a perfect pyramid
but if you sit on it it will hurt all the same
- pointe.PNG (4.18 KiB) Viewed 1188 times
- pointe.FCStd
- (13.59 KiB) Downloaded 15 times
Re: Taper and array
Thanks Thomas. Sometimes I forget about just using primitive shapes. I will try this method too!
