STEP Export/Import colors override (?)
easyw-fc
Re: STEP Export/Import colors override (?)
Post by easyw-fc »
chennes wrote: Mon Oct 11, 2021 1:52 am May as well add the last bit, I suppose! Please have a look at PR 5106.
@chennes
I can confirm after aligning the previous commit, it is working correctly.
There is a small discrepancy in the behaviour because the Object Transparency is expressed in 0-100 where Alpha-channel is instead in 0-255
Anyway I think these features are a great improvement for FC and STP import/export and interoperability.
Thanks a lot @realthunder @chennes :D
When everything will be merged, I'll make an announcement at KiCAD forum about these improvements.
Maurice
chennes
Post by chennes »
easyw-fc wrote: Mon Oct 11, 2021 6:34 pm There is a small discrepancy in the behaviour because the Object Transparency is expressed in 0-100 where Alpha-channel is instead in 0-255
Did I get the scaling wrong, or are you just commenting about the difference in "units" between the Qt color dialog and the output into the STEP file?
Chris Hennes
Pioneer Library System
easyw-fc
Post by easyw-fc »
chennes wrote: Mon Oct 11, 2021 6:37 pm Did I get the scaling wrong, or are you just commenting about the difference in "units" between the Qt color dialog and the output into the STEP file?
In FreeCAD when you apply Transparency to a Shape, through the Combo View, the value goes between 0 and 100
In the FreeCAD 'Set color' per face Dialog, after selecting a face there is the Alpha channel; the value goes between 0 and 255
M4x
Post by M4x »
easyw-fc wrote: Mon Oct 11, 2021 8:43 am
M4x wrote: Mon Oct 11, 2021 7:03 am If the test regarding the STEP import using a commercial / proprietary CAD software is still needed, ping me.
yes please...
you may test this three files
transparent-shape-cube.stp
https://forum.freecadweb.org/download/f ... ?id=166580
this should appear as a solid cube with different colored faces
transparent-faces-cube.stp
https://forum.freecadweb.org/download/f ... ?id=166581
this should appear as a transparent cube with different colored faces
transparent-shape-faces-cube.stp
https://forum.freecadweb.org/download/f ... ?id=166582
also this should appear as a transparent cube with different colored faces
with the same level of transparency of the previous file
I've used CATIA V5 (I think it's from 2016 - unbelievable for a FreeCAD-lover :mrgreen: ) but I think that's not very helpful.
Are you sure you've given me the correct files? They look identical in FreeCAD too.
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.25943 (Git) AppImage
Hash: a65464b722a846bd2999aa2fecdff1132b15b297
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
easyw-fc
Post by easyw-fc »
M4x wrote: Tue Oct 12, 2021 8:27 pm OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Hi @M4x
thanks for testing it in Catia
your FC version is too old to test the STP files
with FC daily of today https://github.com/FreeCAD/FreeCAD/comm ... b8a8fab36b
you should get this transparent cube for the 'transparent-shape-faces-cube.stp' file
in a recent version of FC (like the one I used) you may try to load the file using the following python code:
import ImportGui; ImportGui.open(u'/home/mau/Downloads/transparent-shape-faces-cube.stp')
(changing the file path to your downloading location
my FC importing Preferences
user1234
Post by user1234 »
As i saw in the git, that this new feature is implemented, i also wanted to test it and saw the same like easyw-fc, that the values differs (0-100 vs. 0-255). Is this because it uses different functions (coin vs. Qt)?
Greetings
user1234
chennes
Post by chennes »
user1234 wrote: Wed Oct 13, 2021 12:26 pm the values differs (0-100 vs. 0-255). Is this because it uses different functions (coin vs. Qt)?
Basically, yes: the color selection dialog is a built-in Qt dialog, so uses Qt's normal 0-255 range for all color channels. That's a little annoying/awkward for a non-programmer, so most other places we think of alpha as being a percentage transparency. We could subclass the dialog and change it, but I'm not sure it's worth the effort. That dialog is pretty terrible looking, it would be painful to spend time on it :) .
Chris Hennes
user1234
Post by user1234 »
Thanks for the info! Just said: i did not want to seem unthankful. I like that feature! It is just my inner Monk. Does it make sense that the value of the transparency goes from 0-255 and will be parsed in coin? I know it sounds annoying, but i think when someone is scripting, the a face have other values (and naming) as on object is a little bit odd. (If this is scriptable).
But as ai said, it is my inner Monk and i am nitpicking.
Greetings
user1234
easyw-fc
Post by easyw-fc »
chennes wrote: Wed Oct 13, 2021 12:40 pm
an option could be to add the Transparency value to be applied to selected faces int the 'set color per faces' Dialog, instead of enabling the Alpha channel Qt dialog:
user1234
Post by user1234 »
Or replace transparency with alpha. OK, i stop. I am way too picky.
Greetings
user1234
