Following up...I built from repository head as of last night (1ceaa) and the i3 problem is gone. So that's one bug I won't have to file, and from now on I'll be asking my newbie questions about the development tip version.
How does FreeCAD choose the direction of angle constraints?
Re: How does FreeCAD choose the direction of angle constraints?
Two requests for people looking at the code for processing angle constraints, for once you've modified it:
1. Either document the new behavior or leave a note explaining it on this thread so I can do it.
2. Please choose a simple rule. I think "always choose the arc less than 180deg" would be best.
I see that you have added some info to the Sketcher_ConstrainAngle page based on this discussion.esr wrote:ping
But I cannot reproduce what the paragraph calls the "stable" case.
See image and file:
- The left leg of each V was created first.
- The directions of the lines vary.
- When applying the constraint the order was always: select left leg, right leg and point, and then call the command.
Version: 0.20.25645 (Git)
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- angle-selection.png (12.04 KiB) Viewed 1832 times
- angle-selection.FCStd
- (5.16 KiB) Downloaded 33 times
I haven't had time to check that the "stable case" doesn't reproduce in the tip verseion, as I needed to do work that pays bills.
I can understand removing the "stable case" description if you didn't see matching behavior, but youy really should have left in a warning that the behavior is undocumented and likely to change. This is going to be a signoificant point of confusion for anyone using angle constraints, and users deserve to know that they're not being dimwitted in failing to grasp what the rules are.
I have removed the paragraph you have added. We can have a discussion about it, but, bottom line, editors do have to take care that the information they add is accurate. This obviously includes using the latest version of the program.
Please also react to this:
https://forum.freecadweb.org/viewtopic. ... 91#p534791
For the record: Repeating my test in V0.18 shows the exact same result.
- angle-selection-version-018.FCStd
- (4.36 KiB) Downloaded 31 times
Hmm...just throwing this out, having just experienced it
I was surprised, when in Sketcher, I constrained a 2 degree angle and got 2 degrees rather than 178. In fact, having this thread in mind, even tried to get 178, and couldn't.
But, my goal was to show the 2 degree angle outside the Sketcher (not in TechDraw) for explanatory purposes.
None of the measure tools would allow me to get 2 degrees. Even Manipulator workbench Caliper would only do 178.
Looking at the OP again, and at some of the answers, there is also some confusion about the meaning of complementary angles (total is 90 degrees) and supplementary angles (total is 180 degrees).
See https://en.wikipedia.org/wiki/Angle
This is neither. And I wonder if this ever occurs.
