I was modeling a part where I wanted to sweep along halfway a path from one side, and halfway from the other one. (Ignore the curved base spline. It's not being used for now).
So, as I'd need a multisection transition, I created a Shape Binder to get the profile of the part's face as you can't just select it from the body. But when you select the Shape Binder, FeeCAD suddenly crashes. I also tried SubShape Binder, but it yields the same result.
The fact the Shape Binder doesn't show up as a selectable profile to sweep from suggests to me it isn't the proper way of doing what I intend. Also, the wiki or anywhere else I found don't report this bug. Moreover, on the Sweep wiki page at "Profile limitations and complications" there's no mentioning of Shape Binders.
So, suggestions on how to do it?
Also, have this bug reported (I guess). The terminal error message follows:
#0 /lib64/libc.so.6(+0x3d320) [0x7ff0c5f4e320]
#1 0x7ff02a0e6074 in BRep_TEdge::Degenerated() const from /lib64/libTKBRep.so.7+0x4
#2 0x7ff02a0ebc61 in BRep_Tool::Parameter(TopoDS_Vertex const&, TopoDS_Edge const&, double&) from /lib64/libTKBRep.so.7+0x451
#3 0x7ff02a0ebf13 in BRep_Tool::Parameter(TopoDS_Vertex const&, TopoDS_Edge const&) from /lib64/libTKBRep.so.7+0x23
#4 0x7ff022d78406 in BRepFill_CompatibleWires::SameNumberByPolarMethod(bool) from /lib64/libTKBool.so.7+0x2396
#5 0x7ff022d745e5 in BRepFill_CompatibleWires::Perform(bool) from /lib64/libTKBool.so.7+0xd55
#6 0x7ff022dca53c in BRepFill_PipeShell::Prepare() from /lib64/libTKBool.so.7+0xe5c
#7 0x7ff022dccb66 in BRepFill_PipeShell::Build() from /lib64/libTKBool.so.7+0x36
#8 0x7ff029d16a71 in BRepOffsetAPI_MakePipeShell::Build() from /lib64/libTKOffset.so.7+0x11
#9 0x7ff02286b2bd in BRepBuilderAPI_MakeShape::Shape() from /lib64/libTKTopAlgo.so.7+0x3d
#10 0x7ff02b3970b7 in PartDesign::Pipe::execute() from /usr/lib64/freecad/lib64/_PartDesign.so+0x4e7
#11 0x7ff0c7cb81ff in App::DocumentObject::recompute() from /usr/lib64/freecad/lib64/libFreeCADApp.so+0x9f
#12 0x7ff02838697d in Part::Feature::recompute() from /usr/lib64/freecad/lib64/Part.so+0xd
#13 0x7ff0c7c707ad in App::Document::_recomputeFeature(App::DocumentObject*) from /usr/lib64/freecad/lib64/libFreeCADApp.so+0x26d
#14 0x7ff0c7c75a51 in App::Document::recomputeFeature(App::DocumentObject*, bool) from /usr/lib64/freecad/lib64/libFreeCADApp.so+0x101
#15 0x7ff02079b366 in PartDesignGui::TaskPipeScaling::onSelectionChanged(Gui::SelectionChanges const&) from /usr/lib64/freecad/lib64/PartDesignGui.so+0xf6
#16 0x7ff0c874c780 in Gui::SelectionObserver::_onSelectionChanged(Gui::SelectionChanges const&) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x30
#17 /usr/lib64/freecad/lib64/libFreeCADGui.so(+0x5c6600) [0x7ff0c853b600]
#18 0x7ff0c8750379 in Gui::SelectionSingleton::slotSelectionChanged(Gui::SelectionChanges const&) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x2a9
#19 /usr/lib64/freecad/lib64/libFreeCADGui.so(+0x5c6600) [0x7ff0c853b600]
#20 0x7ff0c874f9c5 in Gui::SelectionSingleton::notify(Gui::SelectionChanges&&) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x2b5
#21 0x7ff0c875d0fe in Gui::SelectionSingleton::addSelection(char const*, char const*, char const*, float, float, float, std::vector<Gui::SelectionSingleton::SelObj, std::allocator<Gui::SelectionSingleton::SelObj> > const*, bool) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0xd6e
#22 0x7ff0c859b895 in Gui::SoFCUnifiedSelection::setSelection(std::vector<Gui::SoFCUnifiedSelection::PickedInfo, std::allocator<Gui::SoFCUnifiedSelection::PickedInfo> > const&, bool) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x6b5
#23 0x7ff0c859c359 in Gui::SoFCUnifiedSelection::handleEvent(SoHandleEventAction*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x139
#24 0x7ff0c59332f5 in SoAction::traverse(SoNode*) from /lib64/libCoin.so.80+0x65
#25 0x7ff0c5acd0e8 in SoChildList::traverse(SoAction*, int, int) from /lib64/libCoin.so.80+0x168
#26 0x7ff0c5b13f90 in SoGroup::doAction(SoAction*) from /lib64/libCoin.so.80+0x50
#27 0x7ff0c5b28edc in SoSeparator::doAction(SoAction*) from /lib64/libCoin.so.80+0x2c
#28 0x7ff0c59332f5 in SoAction::traverse(SoNode*) from /lib64/libCoin.so.80+0x65
#29 0x7ff0c593cceb in SoHandleEventAction::beginTraversal(SoNode*) from /lib64/libCoin.so.80+0xab
#30 0x7ff0c5933948 in SoAction::apply(SoNode*) from /lib64/libCoin.so.80+0xc8
#31 0x7ff0c5ae2139 in SoEventManager::actuallyProcessEvent(SoEvent const*) from /lib64/libCoin.so.80+0x79
#32 0x7ff0c861be12 in SIM::Coin3D::Quarter::QuarterWidget::processSoEvent(SoEvent const*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x22
#33 0x7ff0c8621379 in SIM::Coin3D::Quarter::SoQTQuarterAdaptor::processSoEvent(SoEvent const*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x59
#34 0x7ff0c86520cd in Gui::View3DInventorViewer::processSoEventBase(SoEvent const*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0xd
#35 0x7ff0c86310b5 in Gui::NavigationStyle::processSoEvent(SoEvent const*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0xc5
#36 0x7ff0c863175b in Gui::CADNavigationStyle::processSoEvent(SoEvent const*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x31b
#37 0x7ff0c863118f in Gui::NavigationStyle::processEvent(SoEvent const*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x7f
#38 0x7ff0c8655850 in Gui::View3DInventorViewer::processSoEvent(SoEvent const*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x70
#39 0x7ff0c861917d in SIM::Coin3D::Quarter::EventFilter::eventFilter(QObject*, QEvent*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0xbd
#40 0x7ff0c65c054d in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) from /lib64/libQt5Core.so.5+0xad
#41 0x7ff0c7094432 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /lib64/libQt5Widgets.so.5+0x72
#42 0x7ff0c709c074 in QApplication::notify(QObject*, QEvent*) from /lib64/libQt5Widgets.so.5+0xa84
#43 0x7ff0c83b6160 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x90
#44 0x7ff0c65c0798 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /lib64/libQt5Core.so.5+0x128
#45 0x7ff0c709ab57 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) from /lib64/libQt5Widgets.so.5+0x1b7
#46 /lib64/libQt5Widgets.so.5(+0x20a450) [0x7ff0c70f0450]
#47 /lib64/libQt5Widgets.so.5(+0x20d6e5) [0x7ff0c70f36e5]
#48 0x7ff0c7094443 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /lib64/libQt5Widgets.so.5+0x83
#49 0x7ff0c83b6160 in Gui::GUIApplication::notify(QObject*, QEvent*) from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x90
#50 0x7ff0c65c0798 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /lib64/libQt5Core.so.5+0x128
#51 0x7ff0c6a10ba8 in QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) from /lib64/libQt5Gui.so.5+0x6b8
#52 0x7ff0c69f0c9c in QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /lib64/libQt5Gui.so.5+0xac
#53 /lib64/libQt5XcbQpa.so.5(+0x6f11e) [0x7ff0b329f11e]
#54 /lib64/libglib-2.0.so.0(g_main_context_dispatch+0x19f) [0x7ff0c43d34cf]
#55 /lib64/libglib-2.0.so.0(+0xa94f8) [0x7ff0c44274f8]
#56 /lib64/libglib-2.0.so.0(g_main_context_iteration+0x33) [0x7ff0c43d0c03]
#57 0x7ff0c6611b78 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /lib64/libQt5Core.so.5+0x68
#58 0x7ff0c65bf1a2 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /lib64/libQt5Core.so.5+0x132
#59 0x7ff0c65c76e4 in QCoreApplication::exec() from /lib64/libQt5Core.so.5+0x94
#60 0x7ff0c833aee0 in Gui::Application::runApplication() from /usr/lib64/freecad/lib64/libFreeCADGui.so+0x17a0
#61 FreeCAD(+0x3ee5) [0x55e777c79ee5]
#62 /lib64/libc.so.6(__libc_start_main+0xd5) [0x7ff0c5f38b75]
#63 FreeCAD(+0x500e) [0x55e777c7b00e]
Sweep to Shape Binder bug crashes FreeCAD
Re: Sweep to Shape Binder bug crashes FreeCAD
Please attach your full FreeCAD info as described in the IMPORTANT forum rules linked above. Without the file it is hard to guess what happens.
Here it is
- Full Robot.FCStd
- (246.65 KiB) Downloaded 21 times
FreeCAD info:
Go to Help>About.
The dialogue has a BFB that when clicked will copy all pertinent information about your FreeCAD install to the clipboard.
Then a simple ctl-v will paste it in a reply.
It could be, that info will help the helpers help you.
Go to Help>About.
From the file it is not clear to me what you want to do. Please add a detailed description of the steps to reproduce the issue (which body to activate, what to select, which feature to create, ...)
I can say from what I see, that you cannot use the existing path with the section you have, because it causes self intersections. However, FreeCAD shouldn't crash.
- papyblaise
this is what I understand
- support.PNG (18.5 KiB) Viewed 1082 times
- support.FCStd
- (446.54 KiB) Downloaded 17 times
Yeah, this is sort of what I was intending to do. I'm perfectly aware the approach I took with that path could be just wrong/impossible to do. But indeed "FreeCAD shouldn't crash", as chrisb said. But I think it isn't that.
Take this example I just made: the path is way jankier but it sweeps as expected The thing is. Here it sweeps from a sketch, through this path, to another sketch. In my project, it goes from a sketch, through that path to a shape binder (which I just used because I wanted to "transfer" the sketch from one side to the other, avoid the topological naming problem/don't go from a sketch to a face/yada yada. Btw, is there another way of doing it?)
