Some defects after extrude
Hello
Happy to find your tool and a totally newbie on it
Like I mention in the title I made an extrude from a SVG imported, but the result has some weird faces . I don't understand why.
I hope you could help me, please find below the screen capture below :
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Re: Some defects after extrude
Hi and welcome to the forum!
This is probably only a visual defect. You can decrease in the View attributes the values for AngularDeflection and Deviation - at the cost of more rendering time and a less responsive display.
Experiment with Angular Def and Deviation. You can upload your file and I'll do some experimenting on it if you like.
How to upload the file here?
Drag/drop onto the form where you type your reply is the easiest way.
Ok
Please find the file
- MarcAurele.FCStd
- (97.86 KiB) Downloaded 35 times
It are indeed the named attributes:
- select the body
- switch to the View tab at the bottom
- change the value of Deviation to 0.01
Looks perfect here:
- select the body
Looks perfect here:
- Bildschirmfoto 2021-09-15 um 20.15.35.png (279.18 KiB) Viewed 1171 times
