Some defects after extrude
MrCedric
Re: Some defects after extrude
Post by MrCedric »
Thank you guys, now it's perfect in FreeCAD ;)
But I have tested to import in Blender to check the polygon, and :shock: the bug is syill here :cry:
I have tried an .obj, .stl and .x3d and same problem...
It should be simple, just a curve extruded, I don't understand why it creates some weird things on the edge :?:
drmacro
Post by drmacro »
Did you try the Blender FreeCAD addon?
Direct import in Blender of a FreeCAD model.
https://github.com/s-light/io_import_fcstd
MrCedric
Post by MrCedric »
No I don't have the plugin at this time, I should try it thank you ;)
TheMarkster
Post by TheMarkster »
Go to Curves workbench. Select the Path in the tree. Create JoinCurve. Select the JoinCurve, create DiscretizedEdge. Set the number of points to 300 (or you can experiment here). Select the DiscretizedEdge and create InterpolationCurve. Set InterpolationCurve property Periodic to True (so it is closed wire). In Part workbench, select InterpolationCurve and use Extrude tool.
Snip macro screenshot-b38cee.png (61.76 KiB) Viewed 1361 times
Snip macro screenshot-d2b63b.png (44.89 KiB) Viewed 1361 times
MarcAurele_markster.FCStd
(134.21 KiB) Downloaded 39 times
MrCedric
Post by MrCedric »
Thank you very much ;) really better !
But why my curves are so angular in my Blender import test? The curves are so smooth in FreeCAD before the extrude... :roll:
Did you try to simplify the SVG (Inkscape provides such function)?
TheMarkster
Install Curves workbench from the Addon Manager in Tools menu.
jeno
Post by jeno »
MrCedric wrote: Thu Sep 16, 2021 4:38 pm Thank you very much ;) really better !
Please use the mesh workbench for creating meshes. There you can use different meshers. I use the internal - usually good results and fast.
And you have control over the quality (deviation, angular deflection) of the resulting mesh.
And follow the suggestion of markster
svg (bottom) vs markster (top)
The resultion mesh shows better quality where the curvature is low. The screenshot shows both meshes with flat shading.
Regards
jeno wrote: Fri Sep 17, 2021 5:37 am Please use the mesh workbench for creating meshes.
Which mesher did you use? Did you look at it in wireframe mode?
Standard with default parameters looks weird:
Mefisto with default parameters kills FreeCAD.
Netgen with default parameters kills FreeCAD.
gmsh fails to start, probably a Mac issue.
OS: macOS 10.16
Version: 0.20.25645 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.2
Locale: C/Default (C)
jeno
Post by jeno »
chrisb wrote: Fri Sep 17, 2021 6:04 am
As mentioned in my post I use the internal (aka Standard) mesher of occ. And yes, I saw the artefacts. The bottom piece shows the wrinkled surface.
I suspect that the mesh algorithm ran there in trouble in case the wire has only a very low curvature. Could be that then the allowed deviation leaves more "free room" to compute vertices. Or the import of the svg creates a wire which has a volatile gradient.
But to be honest to evaluate that is above my head.
Regards
