Question about threads and 3d printing
drmacro
Re: Question about threads and 3d printing
Post by drmacro »
3d printed adapter...designed in FreeCAD of course :mrgreen:
For accurate and perpendicular insertion using a cheap soldering iron.
https://github.com/macdroid53/Solder ... pter
Good idea, thanks for sharing. Could be further improved by an adapter to the soldering iron assuring that the insert is properly aligned to the soldering iron. E.g. by a tangent constraint :lol: .
drmacro
Post by drmacro »
I made tips for the iron for each size insert so the inserts self align on the end on the soldering iron
drmacro wrote: Wed Sep 15, 2021 11:48 pm I made tips for the iron for each size insert so the inserts self align on the end on the soldering iron
Top!
GeneFC
Post by GeneFC »
drmacro wrote: Wed Sep 15, 2021 9:52 pm heat set brass inserts are definitely better than printing or tapping threads. IMO :mrgreen:
No doubt, but as always, "it depends". For a simple one-time, low-force assembly a tapped hole would be fine. For repeated use or higher strength the insert rules.
Gene
