Transform xyz position lost after FILLET
stovelsten
Post by stovelsten »
Re: Transform xyz position lost after FILLET
Hi and welcome to the forum!
Your image is not visible, you can attach it to the post. Furthermore you should describe the issue in detail and update to a current 0.19 or if you assume an error, retest it with 0.20.
stovelsten
Thanks.
I upgrade my FC...
The four pics says everything...
stovelsten wrote: Thu Sep 16, 2021 9:03 pm The four pics says everything...
If you say so ... :?
Note that in Part workbench each operation creates a new object with its own placement.
stovelsten
Thanks for the hint...
