Hi
I have done a sketch that check OK by the sketch tool. From this sketch I've done an extrusion. When I try to go on designing from this extrusion I get the message: In order to use PartDesign you need an active Body obj... etc. // use the migrate function in POart Design to but them into a body.
Then when I try the migrate function all i get is a message stating nothing to migrate.
I'm quite novice so a little help transforming the extrusion into a Body would be really great. Or is there something else I miss along the way..?
Thanks!
Extrusion isn't a body
Re: Extrusion isn't a body
Thanks, that helped a lot!
