Is my sketch broken?
I have a sketch with some splines that I suspect is faulty (when I try to use it my drawing breaks). The file I attaches is like the 3d try on this shape. Help would be highly appreciated...
- sketch_1.FCStd
- (68.47 KiB) Downloaded 33 times
Re: Is my sketch broken?
I try to put a chamfer on the rounded edges...
- papyblaise
you do your Pad in PartWb, I suspect you are trying to do the fillet in Part design:?:
by doing a sketch with splines you have a 99.99% chance (risk) of crash
- spline.PNG (7.87 KiB) Viewed 1329 times
- spline.FCStd
- (100.74 KiB) Downloaded 18 times
maybe not 99%... I tried maybe 10 times before it worked.
Make the splines really tangent. It is a known issue that chamfers and fillets tend to fail on nearly tangent edges.
Looked at your sketch: It is not recommended to repeat dimensions if you can use geometric constraints instead.
I tried with tangent B-splines, but chamfer doesn't work either. You may try inserting short straight segments or arcs between the splines. And modeling only one quarter and then mirroring twice could make changes easier.
With ellipses and arcs the work can be done and than there is no problem with chamfer
- sketch_1Willem.FCStd
- (114.79 KiB) Downloaded 19 times
Here is a double mirror example.
- sketch_cb.FCStd
- (38.46 KiB) Downloaded 19 times
