Transformed shape not intersecting support
stevenfalco
Post by stevenfalco »
I'm attempting to design a test-tube holder (design attached). Mostly, it is fine, but I get an error "One transformed shape does not intersect support".
This occurs in the "all posts" multitransform. There are two repetitions - one vertical and one horizontal. In the attached file I have the vertical repetition (LinearPattern003) first, and then the horizontal repetition (LinearPattern002) second.
Curiously, if I reverse the order and make LinearPattern002 first and LinearPattern003 second, I then get "Three transformed shapes do not intersect support".
I cannot see why this is happening, because the shape it is complaining about is in the middle of the repetition, and it should have support.
Is this a bug, or have I done something wrong?
test_tube_holder.FCStd
(53.41 KiB) Downloaded 24 times
Bance
Re: Transformed shape not intersecting support
Post by Bance »
It's a co-planar issue, the post and dimples are tangent to each other. make one smaller/larger and the op will succeed. :D
stevenfalco
Thanks, I'll give that a try!
I also noticed that if I offset the "post_sk" sketch by +12mm on the Z axis (so that it is on the upper surface of the "base_plate") then the transform also succeeds.
Bance
Post by Bance »
These issues are caused by computing limitations/floating point maths ETC.
stevenfalco
That makes sense. I used your suggestion and reduced the post diameter by 0.001 mm. That works perfectly.
Thanks again for the help!
Steve
papyblaise
Post by papyblaise »
it's bad handling on your part
Multitransform the balls horizontally and vertically then the same thing with post
and Refine = true to make the traces disappear
the error message means that by doing the multifransform in the wrong direction, the copies fall into the void
porte tubes.FCStd
(48.75 KiB) Downloaded 27 times
porte tubes.PNG (52.89 KiB) Viewed 986 times
