I am trying to move a Point with the Transform Manipulator (0.20, latest master as of this eve), however it isn't working as expected.
To see this,
- Start a new process
- Open the Draft WB
- Place a point somewhere
- Right Click the Point in the Model Combo View and select Transform
The Transform Manipulator shows up and the point appears to move with it, but when I click OK under the Task View the Point appears in its original position.
Is there something else I need to do to enable the Transform to work with the point like this?
Sj
Move a Point with the Transform Manipulator
- thomas-neemann
Re: Move a Point with the Transform Manipulator
I can confirm this, but isn't it faster to create a new point than to move an existing one?
It is strange the way this object is implemented. The placement is a hidden property that gets linked via expressions to the X,Y,Z properties each time the object recomputes. You can make a similar object in Part workbench in the create primitives dialog. That one can be dragged with the dragger tool and is also attachable.
Thanks for the replies!
This often involves placing vertices in free space (imagine the intersection of a vertical wall chase with a line of holes in a set of joists), for which I use a point as a snap target.
I could set a plane or try to key in the offsets, but to me it's easier and more intuitive to place a Point nearby and adjust it with the manipulator. It has more than enough precision for this application.
I've been experimenting with planning wiring & piping - working out installation methods, routes, lengths - with FreeCAD using the Draft Wire.isn't it faster to create a new point than to move an existing one?
I didn't think of just using another object, that also works!You can make a similar object in Part workbench in the create primitives dialog. That one can be dragged with the dragger tool and is also attachable.
