Hello,
I am new in FC. I have FC 0.19. In addon manager I add the Drawing Dimensioning. When I make any 3D object and want to add any dimension on drawing, this error message shows me below. Please, do anyone know, what is his problem for?
19:18:49 Traceback (most recent call last):
File "C:\Users\Marek\AppData\Roaming\FreeCAD\Mod\drawing_dimensioning\drawingDimensioning\grid.py", line 155, in update
self.SVGRenderer.load( QtCore.QByteArray( '''<svg width="%i" height="%i"> <path stroke="%srgb(0, 255, 0)" stroke-width="%f" d="%s"/> </svg>''' % (drawingVars.width, drawingVars.height, clr, lineWidth, dArg) ) )
TypeError: 'PySide2.QtCore.QByteArray' called with wrong argument types:
PySide2.QtCore.QByteArray(str)
Supported signatures:
PySide2.QtCore.QByteArray()
PySide2.QtCore.QByteArray(bytearray)
PySide2.QtCore.QByteArray(bytes)
PySide2.QtCore.QByteArray(PySide2.QtCore.QByteArray)
PySide2.QtCore.QByteArray(int, int)
Problem with : Drawing Dimensioning
Re: Problem with : Drawing Dimensioning
Drawing+DrawingDimensioning is utterly outdated. Where did you find the recommendation to use it? You should use TechDraw instead.
I never hear about it before. My problem is solved by TechDRAW. Thanks
