Part-WB: How can I add a property expression by Python
lutz_dd
Post by lutz_dd »
In order to follow one object a reference object all Placement parameters are an expression from the follower to the reference (see screenshot).
In case the Cylinder is selected ...
Gui.Selection.getSeletion()[0].Placement.x = 0 ... and not ... <<Cube>>.Placement.Base.x
How can I create this parameter expressions in a python macro?
OS: Windows 7 SP 1 (6.1)
Version: 0.20.25645 (Git)
Python version: 3.8.10
Qt version: 5.12.9
OCC version: 7.5.2
TheMarkster
Re: Part-WB: How can I add a property expression by Python
Post by TheMarkster »
object.setExpression("propertyname","expressionstring")
Example:
App.ActiveDocument.Cylinder.setExpression("Height","Cube.Height")
App.ActiveDocument.Cylinder.setExpression("Placement.Base.x","Cube.Placement.Base.x")
lutz_dd
Post by lutz_dd »
Thanks @TheMarkster.
... and here is the macro.
Context:
A2plus with a Wheel and its Cutout-Cube referenced individual and Cutout-Cube tracks the wheel.
Note:
If it is applied to A2plus-objects the Transform-tool modifies the tree after the movement.
It seems both become a fusion with the 1st object the parent and the 2nd object the child.
Regular Solids of the Part-WB do not show this tree behavior AFAICT.
# -*- coding: utf-8 -*-
#........1.........2.........3.........4.........5.........6.........7.........8
# copyright (c) 2021 lutz_dd
# Copy all Placement parameters from 1st selected object to the second selected
# object to get 2nd object tracks 1st object (eg. wheel and cutout-cube)
import traceback
import FreeCAD, FreeCADGui
def make_dependency():
  try:
    selset=Gui.Selection.getSelection()
    src=selset[0]
    dest=selset[1]
    dest.setExpression("Placement.Rotation.Angle",
                       src.Name+".Placement.Rotation.Angle")
    for hdr in ["Placement.Base", "Placement.Rotation.Axis"]:
      for item in ["x","y","z"]:
        dest.setExpression(hdr+"."+item, src.Label+"."+hdr+"."+item)
    # set recompute flag on the object
    dest.recompute()
    # recompute the document
  except:
    App.Console.PrintError("ERROR: make_dependency() has failed."+os.linesep)
    traceback.print_exc()
make_dependency()
Bance
Post by Bance »
Did you try Attachment?
lutz_dd
Post by lutz_dd »
Obviously not ... but good point.
