Rotary vane pump
Rotary vane pump
Hi everybody,
Could somebody help me please ?
I am trying to design a sliding vane pump on FreeCAD.
Everything was ok until I reached the assembly stage.
I was able to make all the parts fit properly however, matching vanes with stator cylinder seems impossible.
Did anybody ever managed to design a sliding vane pump assembly with FreeCAD.
Thank you for the consideration granted to this post
PS: This is my 1st time ever on a forum so if for any reason I didn't respect the presentation rules, I apologize.
Re: Rotary vane pump
Please read through the thread linked in the big red banner at the top and provide your FreeCAD information. Can you share what you have so far? Did you use an assembly workbench? If so, which one?
Regards / Viele Grüße
Max
Max
- papyblaise
it their a good exemple here
https://forum.freecadweb.org/viewtopic. ... 2&start=70
- thomas-neemann
if you upload the parts somewhere I can try to shoot a video of the assembly with on-board equipment
Dear All,
Thank you for your replies.
My FreeCAD version is:
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
I am using A2plus V0.4.50.
For those who are not used to sliding vane pumps, please watch the below video from VIKING PUMP which will help for understanding of the problem.
https://www.youtube.com/watch?v=IxIio2r_bQE
Basically, I try to find a way to create a tangential constraint between the head of the vane and the internal cylinder of the stator as the vane are mean to wipe this cylindrical surface.
Please check basic assembly below:
My problem looks similar to the one encountered in this subject : https://forum.freecadweb.org/viewtopic.php?t=55555
Could you please let me know if there is a solution to that ?
Thank you
Best regard
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thank you
Best regard
Assembly3 preview
Is this something which can be done using Asm3?
Corresponding thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=62320Slidingvane wrote: ↑Sun Sep 19, 2021 8:51 am [...]
Please check basic assembly below: [...]
Max
Max
Tou can teu punt on surface construint Kike these cases
Re: Assembly3 preview
I would use skeleton sketch for each vane.
Will try to knock up simple example.
- thomas-neemann
Yeap, there it is:
BTW attached FreeCAD file has been created in Link branch (2021.09.16), because that is what I am using (so if you want to examine it you need Link branch installed), but it should be possible to recreate the same in other versions of FreeCAD with assembly3 workbench installed.
