Sketcher -- How to sketch a Lozenge shape (or rounded rectangle)
rek
Post by rek »
I want to make this:
looks easy, but how do you start?
I tried to create a constrianed rectangle then put fillets on the corners but every time i try to make the ends round, i get an error. even if i kind of get close to having a lozenge shape and try to draw 3mm circles at the origin of the fillets or end circle radius, it won't let me. this ended up more of a challenge than I saw coming.
so then i tried creating circles at the ends, nope
I don't know, I've tried a ton of things and it doesn't want to play nice. It's not just a rounded corner rectangle, there's two half circles. i also need to put holes concentric to those circles.
Lozenge_shape_fail_sep_18_2021.FCStd
(8.93 KiB) Downloaded 26 times
I've seen old threads kind of about this, but they were doing the much easier and different thing of rounding the corners, not making two half circles at the end of a rectangle.
Shalmeneser
Re: Sketcher -- How to sketch a Lozenge shape (or rounded rectangle)
Post by Shalmeneser »
Sketcher_CreateSlot
You should follow tutorials. This is such a simple problem.
Look at the Chrisb book (in its signature) : https://forum.freecadweb.org/memberlist ... ile&u=5646 (https://owncloud.gwdg.de/index.php/s/eZ ... 9/download)
Bance
Post by Bance »
:lol: :lol: :lol: :lol:
Shalmeneser
* Draw 2 lines + 2 arcs
* Select 2 points + Sketcher_ConstrainCoincident
* Repeat
* Select 2 adjacent lines + Sketcher_ConstrainTangent
* Repeat
* Select 2 arcs + Sketcher_ConstrainEqual
* Select 1 line + Sketcher_ConstrainHorizontal
* (Select center + axis + Sketcher_ConstrainPointOnObject)
rek
Post by rek »
you seem to have unlocked the mystery of this, thanks. will try now.
I honestly forgot about the arc tool.
Shalmeneser wrote: Sat Sep 18, 2021 8:45 pm * Draw 2 lines + 2 arcs
* Repeat
* Repeat
stuff I did before I read the replies:
i couldn't do it in Sketcher and I studied other threads and someone said "I don't want to make it out of primitives" and I didn't think of trying that so I tried it and now I'm printing the part.
and after trying Shalmeneser's genius strategy of using arcs (instead of trying to use 2 adjacent fillets) i got the result to the left in this pic:
Shalmeneser
chrisb wrote: Sat Sep 18, 2021 10:31 pm ...
Sketcher CreateSlot is equal to Sketcher_CreateSlot ?
Shalmeneser wrote: Sat Sep 18, 2021 10:34 pm Sketcher CreateSlot is equal to Sketcher_CreateSlot ?
Yes, that's what the forum's wiki tag does. Sorry, I had missed your post due to tab open for too long.
rek
Post by rek »
Wow someone created a tool for that. That was fast. Now that's what I call service, thanks Devs!
why does ignorance hurt so much while it's being removed? Thanks :)
drmacro
Post by drmacro »
@rek, the tool has been there for some time...
Also, note, if you ever change your signature because you change your hardware, it chaanges in all previous posts...thus any significance the specifications might have to old posts is lost for posterity.
