FreeCAD won't let me make something?
Hi folks.
Just installed FreeCad under Linux. Right from the start I have a problem. I want to make a circle but FreeCAD won't let me.
- I open new file
- Click dropdown menu 'Sketcher'
- Create new Sketch
- XY Plane and OK
Choosing 'Create a circle in sketcher' and want to make a circle.. but nothing happens. Same for line tool and others.. Do I forgot something?
edit...
Managed to install the FreeCAD_weekly-builds-25645-Linux-Conda_glibc2.12-x86_64.AppImage. And still got the same problem.
And I'm using Manjaro as distro. I have a suspicion that might be the problem.
edit..
Video of the problem https://www.mevue.com/v/ni1wj3ie1021
- I open new file
- Create new Sketch
- XY Plane and OK
edit...
edit..
Re: FreeCAD won't let me make something?
Can you create things in Draft, Part WB, or primitives in PartDesign?
I use manjaro, no problems for me.
Please have a look at the big red banner at the top and provide us with more detailed information. Could you upload the file to make sure it's not corrupt? Could you create a screencast?
Regards / Viele Grüße
Max
Max
Have a look at the Mouse Models and check if one of them works.
- papyblaise
it is not enough to say to it "make a circle" (or a straight line) you have to click for a starting point and an ending point
Ok I've uploaded a screencast from the problem. Yes I'm clicking when I want to draw something.
Are you using a special mouse, such as a Space Navigator?
What mouse model are you using? Default or something else? If default, try some others.
Gene
Gene
In the video I used the touchpad.. But also a normal mouse connected isn't doing anything.
