Absolute newbie to free cad <5 hours, but in my free time ive gotten interested in 3d modelling and wanted to try my hand at a simple keyboard plate(how i was wrong). After importing a DXF file of the plate, i set about creating the model. I took the draft into the draft workshop and made it a sketch, once that was done, i headed to the sketcher to check the constraints. lo and behold, I have 7000 degrees of freedom. although this may have been answered before, is there any way for me to do this automatically? Since if i have to do all 7000 manually im giving up
To anyone who helps thank you so much!
attached below is the image of my sketcher and the dxf file of my plate
Auto constraint in sketcher
- 7c18a3476a59afc467da38d37a98214a3c99dafd_switch.dxf
- (166.54 KiB) Downloaded 47 times
- WhatsApp Image 2021-09-20 at 17.27.59.jpeg (283.63 KiB) Viewed 1612 times
- papyblaise
Re: Auto constraint in sketcher
If you draw it with Fc, with which workshop, it seems to me Draft, why have it exported in DXF?
you have to do it in PartDesign> Sketcher
you make an outer rectangle, with the lower slit which is unique
then the keys by multiple copies
I leave you the pleasure of adding the constraints of dimensions
- keybord.FCStd
- (208.2 KiB) Downloaded 43 times
- keybord.PNG (4 KiB) Viewed 1573 times
7000 DOF is far too much to be handled performantly. You should model this differently, e.g. by modeling one key, and then use clones of this.
For sure you are right. I wanted to test this with the autoconstraint routines just for fun:
>>> ActiveSketch.detectMissingPointOnPointConstraints()
1904
>>> ActiveSketch.makeMissingPointOnPointCoincident()
>>> ActiveSketch.solve()
>>> ActiveSketch.detectMissingVerticalHorizontalConstraints()
1904
>>> ActiveSketch.makeMissingVerticalHorizontal()
Those work fine in a reasonable time (under one minute).
Afterwards, I tried to run the detection and creation of equalities.
The detection was very fast (1826) equalities detected, which would substantially lower the DoF. However, the algorithm seems to run a solve() for each pair (see below for reasoning). My computer had been running at that time for over one day with this task and it was not finished yet.
My lesson learnt was that it may make sense to add a parameter to the makeMissingEquality() so that a single solving is made at the end. So I went to the code, only to learn that I had already foreseen that and that the parameter is there (It is even documented!!!), so I tried passing False to it.
It took under 10 minutes to arrive to a heavily redundant system (and that was probably the reason for the solve after each, to remove redundants by pairs). However, deleting the redundants of this system is still running now (more than 12 hours later).
Apparently, I should look into improving this equality routine, as it is not well suited when many equal segments of a same length exist.
All in all, well working of autoconstraining for coincidents, horizontal and vertical and poor performance of equality autoconstraining (at least in this specific case).
For a reference to autoconstraining routines (there is a link to the Python documentation):
https://forum.freecadweb.org/viewtopic. ... 95#p260195
I wonder if somebody has used these routines and has some extra input...
Interesting test. I haven't used these routines, but have bookmarked your post .
I first wondered where the redundancies come from, but it is clear that every rectangle with coincidences, horizontal and vertical constraints will create them.
Thanks for all the responses to my post, being a newb to this, i believe there are definitely things im missing in the creation of this. I may get back to this project in the future, but will be putting it on hold for now. I hope that in the future i will finally understand this, but in the mean time, i will be trying my best to understand freeCAD and your solutions
