How to hollow out this shape
fatbeard
Post by fatbeard »
I have a shape like this:
Screenshot from 2021-09-20 15-10-06.png (143.52 KiB) Viewed 798 times
and want to make it hollow with a 1mm wall thickness.
The "make a thick solid" tool does not work: it reports Thickness not possible on selected faces/edges. , Error, Select an edge, face, or body from an active body. (with the body selected) or BRep_API: command not done depending on the item(s) selected but does not do anything else...
Surely I am doing something wrong, but can not find out what: the error messages are, ehrmm, not very helpful...
I even simplified the block, reducing it to only flat surfaces and a single padding, only to get the same list of errors.
OS: Linux Mint 20 (X-Cinnamon/cinnamon)
Version: 0.19.
Branch: unknown
Hash: 0d9536ed3e8c7f40197b5606e1b7873625e1d6fe
Python version: 3.8.10
Qt version: 5.12.8
OCC version: 7.5.2
SenseoXLfloat.FCStd
(42.61 KiB) Downloaded 19 times
papyblaise
Re: How to hollow out this shape
Post by papyblaise »
you did not specify which faces to open, which to keep
openBrain
Post by openBrain »
Thickness feature doesn't work this way. It works as if you were hollowing the solid by "digging in" it from a face (several faces). And you basically select this(these) face(s). You can't hollow a plain solid that shall keep it's external envelope identical at the end.
fatbeard
Post by fatbeard »
Thanks.
The picture that @papyblaise showed was almost correct (the comment was spot on :oops: ), @openBrain nailed it.
.I did it before, but got a little confused juggling 4 different CAD programs at once...
Screenshot from 2021-09-20 16-47-14.png (120.51 KiB) Viewed 713 times
Next challenge: webbing, magnet holder and an attached lid...
kisolre
Post by kisolre »
fatbeard wrote: Mon Sep 20, 2021 2:58 pm Next challenge:
Keep us updated on your progress :)
domad
Post by domad »
Greetings to the Community!
.... since it resembles a bottle, I am attaching an example of a workflow that allows you to empty it (entirely) maintaining a thickness of 1 mm, then create the neck (which could be threaded) finally open literally to show the internal part with the edges connected like the outside. :)
SenseoXLfloat.FCStd
(709.8 KiB) Downloaded 17 times
fatbeard
Post by fatbeard »
Nice bottle! But I wanted to avoid subtracting two solids...
Just a quick update on the status:
Screenshot from 2021-09-21 14-56-30.png (136.29 KiB) Viewed 547 times
I know, the lid hinge is not in the right place: when closed, there will be a 1mm ridge. Working on that.
I also have to route an extremely densely packed 12-layer PCB with lots of constraints by the end of the week, so be patient.
SenseoXLfloat.FCStd
(417.78 KiB) Downloaded 12 times
papyblaise
voilà un joli bidon
bidon.FCStd
(369.52 KiB) Downloaded 12 times
