Spherical Gear - revolve not working
Hi:
I'm new to all this, so forgive me if this have been dealt with previously. I'm trying to create a spherical gear with teeth in both axes. I tried multiple methods... first I tried taking a sphere and simply using a subtractive sweep in both axes... but I got basically a blank object... it looked like the algorithm totally failed, the result was a single deformed triangle with the rest of the object being empty.
Then I tried making an additive sweep with teeth in one direction, and another but with inside gears in the other direction with the hope of using a boolian operation to 'cut' the teeth from one object from the other... but that did not work... it failed badly.
Nest I tried an additive sweep in one direction followed by a subtractive sweep in the other, but it refuses to make the shape...
I've tried attaching an image where you can see FreeCAD stubbornly refusing to cut all the teeth, hopefully that works.
Is there a known bug with sweeps? Would anyone know how to make this work?
Thanks for your time, cheers!
- papyblaise
Re: Spherical Gear - revolve not working
what is the use of a waffle mold to place a scoop of ice cream
- moule à gauffre.PNG (52.5 KiB) Viewed 1654 times
- moule à gauffre.FCStd
- (523.05 KiB) Downloaded 25 times
- Shalmeneser
Thank you Shalmeneser.
To papyblaise: you seem to believe that if you have no use for it no one else should... What I want to use it for is my business, I wanted to know how to make it, why I wanted to make it does not dictate how/if it can be made. why post such a comment? it is unproductive, you clearly didn't know the answer so why post the comment?
- papyblaise
this makes the exercise more fun for me, but if it shocks I put them back in my pants (french expressions)
do you prefer "Headbreakers" medieval weapon
- casse tête.PNG (12.11 KiB) Viewed 1432 times
Greetings to the Community!
After a first experiment this is what I managed to get (very similar to the one seen in the video https://i.imgur.com/382WZ0z.gifv), obviously it needs to be improved.
If I have time I will try to model the pinion as well.
For now I cannot attach the FC file because it is "heavy" and raw.
- spherical_gear.gif (559.9 KiB) Viewed 1404 times
How should he help if he does not know for what purpose this part is? You can not make a spherical gear isotrop, so he must know the purpose for the right workflow.
Greetings
user1234
- papyblaise
Do you prefer a boule to play pétanque on the ice floe?
solution: do the part that subtracts at scale 1.01 so as not to be blocked by the coplanars
- boule a crans.PNG (56.62 KiB) Viewed 1350 times
To papyblaise:
I was actually thinking of a mechanical eye, the special gear would permit rotation the same way an human eye does.
Cheers!
Cheers!
- papyblaise
that's a more serious project, with a hemispherical movement
2 simple examples: the movement of video surveillance cameras
or even simpler: the electric mirrors but the movement is very limited
