I want to extrude this but it says I can't, it says Failed to Validate broken face. is there anything can do to fix this
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Can't extrude
Can't extrude
- Screenshot 2021-09-21 213738.png (13.6 KiB) Viewed 1121 times
- Screenshot 2021-09-21 213436.png (8.89 KiB) Viewed 1122 times
Re: Can't extrude
T-junctions are not allowed in extrudable sketches. Remove the short arcs or make them construction.
Re: Can't extrude
ok well thanks for the tip I just ended up deleting it and manually making each part separately.
- Screenshot 2021-09-21 224420.png (6.87 KiB) Viewed 1053 times
- Screenshot 2021-09-21 224402.png (4.95 KiB) Viewed 1053 times
Re: Can't extrude
The Trim function is helpful in such cases, but simple sketches are usually a good idea too.
- papyblaise
Re: Can't extrude
and whitout sketches , only primitives
- etoile.FCStd
- (23.12 KiB) Downloaded 20 times
- etoile.PNG (21.3 KiB) Viewed 951 times
Re: Can't extrude
another approach is to draw 1/6 in sketcher, pad it and make a multitransform
- Hexagon.FCStd
- (26.17 KiB) Downloaded 19 times
Re: Can't extrude
I have tried using Arch Wall. I faced the following issues:
- I could not put the inner circle into the sketch and had to wall it separately
- there is a defect at the left lower corner. Did I do something wrong or is it a limitation of the Wall tool?
- hexWall.FCStd
- (16.3 KiB) Downloaded 19 times
Re: Can't extrude
Greetings to the Community!
An example of an almost total geometric constraint, in which, through the use of an electronic sheet, various hexagonal-based prisms can be generated, modifying only the external side of the hexagon and the height of the final prism.
The thickness of the ribs is of equal size which will be proportional to the variation of the size of the side of the hexagon, as well as the central hole.
This simply wants to be an example (which can be improved), obviously by creating/setting different parameters and relating them, appropriately, to each other, it is possible to modulate and obtain different proportions by evaluating, in the 3D view, the result in real time.
- hexagonal_profile_ribbed_hollow.FCStd
- (20.79 KiB) Downloaded 22 times
- hexagonal_profile_ribbed_hollow.png (271.96 KiB) Viewed 829 times
- Shalmeneser
Re: Can't extrude
IMHO, inner radius and thickness should be in the spreadsheet (eventually with a formula).
Same dimension should be written once only.
- Capture du 2021-09-22 19-09-17.png (88.35 KiB) Viewed 758 times
- hexagonal_profile_ribbed_hollow_SHALM.FCStd
- (26.01 KiB) Downloaded 17 times
