Generally what happens is that for some reason, the deviation/deflection values for rendering end up with a very low value, hence any curved object takes forever to render.
strange behavior revolving a circle (solved)
Re: strange behavior revolving a circle
The issue was specifically AVX and Netgen. Some lesser processors do not have AVX and will not work with versions of Netgen that are compiled to use AVX.
Probably not an issue in this case.
Gene
In general and for the next time (since the issue seems to be resolved already):
- Can you please post here your example file to test?
- Does this file work with FreeCAD 0.19 as downloaded from our website?
This assures that you test with preferences that are not mangled since the preferences of 0.19 are stored in another folder than the ones of FC 0.20.
Why "invalid" rather than "solved"? OP had an issue and found a solution. If another user has same problem, it would be perfectly valid to look at this thread...
Because he had mangled preferences. Therefore there was no real bug and nothing was done by the developers to "fix" this.
The problem described in the thread is therefore not helpful for others - it is not clear what was wrong with the preferences and how he managed to break the preferences. Therefore there is also no info how the reporter solved the issue.
"[invalid]" implies therefore other future users searching for help that this thread won't solve their problem.
This isn't "[Bug]", just "[Solved]" which means OP solved its issue. More than 95% of threads tagged with "solved" never implied any code fix...
If one user can inadvertently damage preferences, others can also. And I gave solution, that OP indeed didn't reproduce in the thread.The problem described in the thread is therefore not helpful for others - it is not clear what was wrong with the preferences and how he managed to break the preferences. Therefore there is also no info how the reporter solved the issue.
Anyway, I don't really care if you want to introduce your hunky funky "invalid" tag.
About half of the posts in the Help forum would end up as "Invalid". A lot of the difficulty can be attributed to user error.
Might be OK for a bug tracker, but pretty unfriendly for a Help forum.
Gene
Gene
